Question about Panasonic SD-YD250 Bread Maker
Need replacement pan for YD250 - Panasonic SD-YD250 Bread Maker
Panasonic SD-YD250 Bread Maker uneven bread
Usually this happens when the mixture is too dry. Flour contains varying amounts of moisture, thus water needed also changes. Follow User Manual to help solve the problem or add additional water one tablespoon at a time. The dough should be a little more tacky than conventional bread dough. This will allow the dough to flow out more evenly and be less dense. This is a very important step that many persons miss.
Apr 04, 2014 | Panasonic SD-YD250 Bread Maker
The dough doesn't seem to be mixed properly. I can see the yeast particles, the dough is tough and not-elastic. Doesn't seem to have risen. When I put it in a warm place to rise, it seems to rise a...
Hi, It could be that the paddle is sticking or the belt is slipping. This would cause the ingredients not to be mixed properly. Take the empty pan and paddle out of the machine and see if you can spin it freely by hand. It shouldn't stick. If it does stick then the sealed bearing is frozen and a new bread pan is needed. If everytrhing is fine, then check the belts. Belts and motor are located in base of the machine. Unplug machine before working on the belts. Hank
Nov 11, 2010 | Panasonic SD-YD250 Bread Maker
Print user manual
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Kitchen-Appliances/Bread-Makers/model.SD-YD250
You can download the manual and then print it.
Jul 13, 2009 | Panasonic SD-YD250 Bread Maker
The pan is stuck in my Sunbeam bread machine
I just had the same problem. What the manual either does not tell you or hides quite well is that you have to TWIST the pan before lifting it out. I don't know why this was listed under the Panasonic bread machine when it clearly refers to the Sunbeam bread machine.
Feb 05, 2009 | Panasonic SD-YD250 Bread Maker
Thermostat needs replaced
After removing the screws there are two plastic latches hidden on the inside of the plastic ring, with a flat headed screw driver tease these open. located on the inside of the ring and in the centre on both left and right sides.
Feb 22, 2008 | Panasonic SD-YD250 Bread Maker
Panasonic Bread Machine
I had a Panasonice bread machine before without a yeast dispenser. You just put the yeast at the bottom of the pan; put it in fiist to keep it away from the liquids Yeast then dry ingredients then liquids. Works fine.
Sep 20, 2007 | Panasonic SD-YD250 Bread Maker
Panasonic SD-YD250 Bread Maker Logo
44 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
