My washing machine wont unlock at the end of the cycle? I purched this washing machine about 2 years ago from DEC electrical, that has now shut down. The washing machine does its thing and when it's finished it wont open and there is no way to open it. sometimes i have to wait and hour for the timer to click and i can get my cloths out and then other times it instantly opens? what is the problema and what can i do?
  • 15,935 Answers
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Why is my washing machine not shutting off the water and flooding?
It sounds like you need to replace the Water Solenoid or Solenions.
This is where your washer hoses connect to your machine . They are little electric valves that open and close to put water in your machine . It is getting stuck opened and over filling the machine . Here is a like to where I get parts to fix almost anything . Good Luck !!! Grant
http://www.m-and-d.com/Appliance-Parts.html
Aug 11, 2014 | Washing Machines
I have an LG WM1814CW wash machine that shuts itself down in mid cycle. No codes given??
We had a problem like this with our whirlpool duet washer and we found out that the drain filter was restricted by of all things one of our kids socks. I cleaned out the filter and have not had the problem again so far and its been about a year now. The filter on ours was behind a little door that screws open and is in the drain line.
May 04, 2014 | LG WM1814CW Front Load Washer
Door wont open on washing machine zwf16581w at the end of the cycle
The door is designed to stay shut at the end of a cycle usually for about 4 minutes, even if you switch the machine off at the mains. Other than that you probably need a repair.
Dec 17, 2011 | Zanussi Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool front loader not working - Control Lock Light On
Press the End of Cycle Signal for 3 seconds until the Control Locked light turns off.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loading LG washing machine approximately 2 years old and now it will not unlock the door when the cycle is finished. The child lock is not on and there is no water in the tub but the door...
you will need to manually unlock the door... remove the top two screws in the back ..reach way down at the bottom of the door lock there is a pull down on the lock it will release the door... if your arms are not long enough use a bent coat hanger....once you have the door open .. remove the wire around the gasket .. remove outer gasket unscrew door lock. unplug wires and replace door lock...
hope it helps
Aug 13, 2008 | LG Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
