Question about Microwave Ovens
Does a kenmore central vac model 116.4803080c have a filter
Does it have a replaceable filter
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
We got a new kenmore frige and when we hooked up the ice maker/water dispen. water came running out from under.
check your connection where you hooked water up to the frig. Also on some models there is a water filter on the front toe-plate. These filters will leak if they have a crack in them, so try replacing the filter first. If the filter and the connection are not the problem, you might have to replace the filter housing. Hope this helps, Clint
Mar 21, 2011 | Microwave Ovens
Where are the vent grille mounting screws on kenmore microwave model 80592 to change filter or light bulb?
The Grille mounting screws directly on top of the microwave 2x screws hold the vent to the frame. check out the picture here.
Or paste it into your browser: http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f50027636-00003.png
Take off the 2x screws list# w142 and you will have access to the microwave light and filter if one is present.
Dec 06, 2010 | Kenmore 80599 Microwave Oven
Le moteur de mon aspirateur duo vac model 3200 refuse de démarrer, cette aspirateur à plus de 10 ans et a toujours fonctioné, La semaine dernière le moteur a...
Bonjour M. Grenier, le probleme ce situe dans la carte électronique de votre aspirateur central Duo Vac. C'est probablement le relais qui est défectueux. Il peut rester en position ''on'' ou autant en position ''off'' lorsqu il devient capricieux. Contactez nous au www.aspirateursenligne.com pour des renseignements et les pièces
Bonne chance
Nov 16, 2010 | Microwave Ovens
Kenmore microwave model 665.69682992. I am attempting to replace the door on this model. I ordered the new door but find that the hinges are installed in the new door and cannot figure how to get the new...
I am looking to replace my Kenmore model 665.61612100 combination microwave with an updated model of the same size and specifications. Any suggestions???
Sep 08, 2010 | Kenmore 62622 Microwave Oven
I have a Kenmore Microwave Model #363.62709200. I
If you go to www.appliancepartspros.com and do a model search you can find what you are looking for.
Jan 03, 2010 | Kenmore Microwave Ovens
Remove Kenmore Mod. # 5648598601 from wall.
A lot of those you can replace the bulb without taking it down. There should be screws at the top that lossen up the vent in the front. Remove the vent, might have to open the door and slide it to the left (a little latch) then you should see a filter that just comes out and behind that is the bulb. I would try that before taking it down Forgot to mention that in the other e-mail.
Mar 04, 2009 | Kenmore 80412 Microwave Oven
Need charcoal filters for model 85059 kenmore mikeowave oven,Sears said to contact you people
no. he got it right. I have the exact same one with the same model #.
here's the rest of the info from mine.
Kenmore Sears. Goldstar Manufactured in Korea. Feb 1990. 501-850900. Model#85059.
?# 3B72630L. 1.35KW
Jul 22, 2008 | Goldstar Microwave Ovens
Kenmore microwave
Since it's under warranty, they will replace or repair it at their choice, and if they replace it, it will be the same model or a "like model".
I'd ask them about it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Kenmore 63663 Microwave Oven
Microwave Ovens Logo
105 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
