Question about Maytag Washing Machines
How old is my maytag washer w10140921d top loader
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
the dr
  • 447 Answers
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Posted on Sep 27, 2007
  • 686 Answers
SOURCE: Maytag Performa top loader stopped spinning
GO TO www.repairclinic.com ENTER YOUR MODEL NUMBER AND SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 THEN LOOK FOR PART NUMBER 1042142 THIS MAY BE THE PROBLEM. IT SAYS A WORN BEARING WILL CAUSE SLOW OR NO SPIN. YOU MAY HAVE NOT NOTICED SLOW SPIN TILL NOW BUT I'D SAY CHANGE THAT AND YOU SHOULD BE GOD AGAIN GOOD LUCK
Posted on Apr 12, 2009
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
What would you recommend for a good super capacity top loader washer? My 15 year old Whirlpool just died. Don't really trust electronic controls, reviews of he top loaders are so mixed, I am unsure. Also...
To be honest I really don't trust electronic controls due to the fact that the majority of the repairs i do on front loader machines has to do with the electronic controls. In my opinion top loaders are more reliable. they get the job done. If you were to get a top loader i do recommend whirlpool, even though i agree that the quality is down. I also like the whirlpool cabrio, its a top loader but has electronic controls. it uses less water and soap just like a front loader. Whatever you do decide to purchase, I highly recommend that you purchase the extended warranty. This way if there is ever a problem, you know that you are covered.
Feb 03, 2011 | Washing Machines
I have a top loader Maytag that is about 5 years old. It has mold that is visible around the top gasket - above the "barrel" How do I completely clean this machine of mold / mildew.
There is 2 clips to raise the top of the washer. You need a flat blade, like a putty knife or similar. while trying to lift the top at the seam, push the flat blade in at the right front corner it should pop up. Repeat for the left, this should let you get to the underside to clean around the gasket etc.
Sep 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
May 12, 2009 | Maytag PAV2300 Top Load Washer
Does not spin or pump water out
Is it a front loader or top?How old? What model? need more info If front loader sound like you need to remove hose from pump and cheak for obstruction in pump good luck:)
May 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
