Question about Acer Computers & Internet
Acer monitor is blank and power light flashing green and orange
SOURCE: monitor screen blank and LED orange light flashing
I think you should try clean the cmos first... its not a monitor problem but for the system.
Posted on Aug 20, 2007
scottyfixit
  • 186 Answers
SOURCE: Blank Screen, Flashing orange power light...
1st Idea - Let's take a look under the cover. I'm not sure how tech savvy you are, but I'm sure you're pretty good if you have a soldering iron. Once inside locate the power supply section. See if you see any blown capacitors on it or any other boards. One obvious way is to see if they are bad is if they have bulging up tops. There could be some weak or bad ones that aren't popped up, but let's start from there. If there are any bad caps, they are dirt cheap price wise at an electronics shop. Keep me posted and let em know what you find. - Scotty
Posted on Apr 30, 2008
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
graemevm
  • 519 Answers
SOURCE: my acer monitor's power light is blinking green
This could indicate that there is a problem with your display card and not your monitor. Try plugging you monitor into another pc and check for the same problem.
Best wishes,
Graemevm
Posted on Jun 06, 2009
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
Why is the power light on my Acer monitor flashing?
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Acer Computers & Internet
My Acer X193W power light is orange and it flashes on and off. Pushing the power button has no effect. Only by unplugging it does it go off. Once it's plugged back in, it continues flashing.
the problem is not in to your Monitor the problem is in your PC
  1. press your keyboard nun lock if working and if the light of the keyboard is Green.
  2. remove the memory of your pc and clean it
  3. also check your video card
remove your LCD monitor from the pc and check if you can press the menu of your LCD monitor if that working means your pc is the one have a problems
Nov 02, 2010 | Acer X193W LCD Monitor
Acer AL2216W's green light goes off completely when the computer is turned on. When I turn on the computer and monitor, there is green light on on/off button while an irritating Acer logo is showing up....
You may have failure in the power supply due to bad caps, bad inverter circuits such as shorted transistors, transformers, bad lamps. You need to open it up and make some measurement, see example of failed ACER monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 13, 2010 | Acer AL2216W LCD Monitor
Hi I am running Triple Acer AL1912 LCD monitors on a Mo-View triple monitor stand. I have run these for a couple years without fail. PC is running 2 video cards a NVIDIA GeForce FX 5600 and a NIVIDIA...
Most comon problem with monitors are bad caps in the power supply, any good reapair shop should be able to fix them easily, see pictures of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
At least you will have some info so you will not get ripped off by repair shops.
Mar 01, 2010 | Acer AL1912 19" LCD Monitor
Nothing on screen, gren and orange light flashing
You more like have bad capacitors in the power supply. Open it up and look for capacitors with bulging tops. http://en.wikipedia.org/wiki/Capacitor_plague
Common problems fro 2~3 years old monitors/ TV.
Jan 03, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
