Question about Kinderkraft Vermont Crib
I can't get the slide rail on.
I got the whole crib together except the slide rail. How do we get it on.
  • 340 Answers
The customer service reps at Products America are very familliar with the type of crib you have and the hardware that it uses. You can call 800-205-9642 or 800-772-1041 and they should be able to help you figure out what the problem is. You can also check out their very user-friendly website at 800-205-9642 or 800-772-1041.
Posted on Jun 19, 2009
How to convert from crib to toddler bed
It converts from a crib to a daybed, by taking the front sliding rail completely off. The rail will slide up out of the groove.
Hope this helps.
May 15, 2010 | Storkcraft Baby Aspen Stages Crib
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Looking for teething rails for the Bethany James crib.
gud morning..maybe you can put a replacement of the plastic piece that slides or snaps on and covers the entire top of each side rail, you replace it by puting a cloths on it..and make sure that the child is safe.
thank you
Feb 20, 2009 | DaVinci Leonardo Crib
Can not get crib together...need instructions
called the people we got it from and they came and put it together. It would have been impossible without them or instructions
Sep 16, 2008 | Cosco 2 in 1 10-185-WHO Crib
Sliding latch/railing
Go to www.productsamerica.com You can get hardware for any crib made in the US I think within the last 10 years. Hope this helps.
Aug 24, 2008 | Childesigns Dayton 21-815 Crib
Model # 4960...help
I ended up having to take the tracks off of the crib and 'force' the slider things through. I then screwed the tracks back onto the crib. I was told that you could just leave the tracks on and the sliders would just slide right on.....that wasn't true for me. I wasted 3 hours trying their way and finally got fed up and did it my way.
Jun 26, 2008 | Delta Luv Lauren 4341
Kindercraft Convertible
If it is like my KinderKraft crib and you want to make it into a day bed, here is how to do it:
Where the bottom of the sliding rail rests at each end, there are small rubber bumpers that stop the rail from going down too far. With the rail in the up position, unscrew the rubber bumpers (remove completely), then drop the rail as usual except it will continue going down. Let it go down until it comes off the guides and you are done! I replaced the rubber bumpers on mine so I don't lose them, though. I actually just did this two night ago! :) Good luck!
P.S.
Your matress needs to be in the lowest postion in order to safely use this crib as a toddler bed!
My email is sharon_d95@comcast.net. If I can help you any more with this, feel free to contact me. If your crib is very similar to mine, I can email you a copy of the manual.
Jun 14, 2008 | Kinderkraft Vermont Crib
Delta luv crib hamptons 3 in 1 crib manual
I was looking for the same thing. My crib has directions on the board that the mattress sits on. It basically says to remove step 4, which is the rail that goes up and down. You slide it up a little from its bottom position and then the screw heads come through the slots that you see and then the whole thing comes off pretty easily. I has to push and pull a little to get the screws through but it worked fine. There is no additional piece that goes on, just stays like that and is stable. My son is very excited to give it a try tonight. Sort of a long way down though! Need to find some extra pillows for a safe landing! Good luck to everyone.
Dec 01, 2007 | Delta Enterprise Hampton 3-in-1 Crib
Crib assembly
i have a crib with the same model number, except it's not cosco..at least i don't think it is. it's dorel. anyway, i have the same crib i believe, and if you say all the parts and hardware is there, maybe you forgot to put on the stoppers at the bottom of the sliding rail. that's the only thing i can think of. hope it helps...if not..try see if you can contact dorel.
Nov 28, 2007 | Baby Gear
Crib n' twin 580
Go to these people, they are AWESOME and will help you!!!
http://www.productsamerica.com/
Aug 05, 2007 | Kinderkraft Vermont Crib
Kinderkraft Vermont Crib Logo
162 people viewed this question
Top Kinderkraft Baby Gear Experts
Joyce Nokleby
Craig Butler
Craig Butler
wcdoc1953
wcdoc1953
Are you a Kinderkraft Baby Gear Expert? Answer questions, earn points and help others
