Question about Amana 45 Pint Electric Dehumidifier - D545E
Haier not working
I got a haier and got a lo in window what does this mean
Why has it stopped running, but still shows temp and humidity?
I may have reached the humidity level that you have set it at. Press the HUMIDITY button until it says "Lo". That should put you into continuous run mode.
Good Luck.
Jun 09, 2014 | Haier DE65EJ Dehumidifier
Unir ran good for 8 months then cut off with current humidity reading LO. Humidity is not LO. Have to set below 40% then runs all the time. The AUTO humidistat sensor must be broke. 1 year...
In addition to a faulty humidistat sensor, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, contact Haier Customer Support
1-877-337-3639, before your warranty expires.Haier units will generally show an E1 code if a sensor or circuit is faulty and unit will not run at all.
I hope this helped you troubleshoot & solve the problem
Aug 11, 2011 | Haier DE65EJ Dehumidifier
WE have a model DE45EJ - T. The humidifer is not pulling in anything or making any noise or doing anything at all. It says Lo in the bottom reading.
The "LO" in the bottom reading, Indicates the current humidity extraction setting. If the unit was operating properly not that long ago (A couple of hours), the reason it is not doing anything, maybe that there is no humidity above "LO" = 30% at this time. Once it the humidity level rises above 30%, it should turn ON and function normally.
Also, was the timer set to turn the unit OFF at a specific time?
If the unit wasn't working properly a couple of hours ago.
Check the air intake filter for excessive dirt or clogs. Turn the unit OFF & unplug it before removing the filter. While the unit is OFF, remove the bucket, empty it if needed and carefully replace i, making sure it is fitted properly in to it's holder.
Air obstruction: The dehumidifier requires an minimum of 12" to 18" clear air space around the entire unit.
Hope this has helped you further troubleshoot and solve the problem. To assist you further, in case you have misplaced yours, I am including a link to your Owner's Manual that you can download and print for future reference. http://www.haieramerica.com/en/asset/product/4ba7175e54
Jun 22, 2011 | Haier 45-Pint Dehumidifier
What does e1 mean
For many window air conditioners this code is simply a reminder to clean the air filter. After like 750 hours of run time this code pops up and you have to clean the filter and then reset the unit before it will work again. To reset the code you need to simply unplug the unit and then plug it back in again.
Hope this helps; good luck.
Jun 13, 2011 | Haier 45-Pint Dehumidifier
Unit will not run and the code 'LO' show up. What does the 'LO' code mean?
Hi, it simply means that the humidity level is lower then 35% the lowest setting on the dehumidifier...
It will not run when showing that...
Jun 09, 2011 | Haier 45-Pint Dehumidifier
Haier 65 pt dehumidifier the lo light is on and the bucket is not fu;; and the filter is clean. ????
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 07, 2011 | Haier 65-Pint Dehumidifier
"Lo" reading at humidity setting
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end. if this helps please rate me.
May 17, 2011 | Haier Dehumidifiers
The dehumidifier wont work even the lights was on and it show Lo all the times and we do not know why it happen and how can we get it fixed as we live in Oshawa, Ontario?
I found this on the web
Q - Will my dehumidifier work in a cold room ?
A - A dehumidifier will not operate satisfactory in a room that is below 65 degrees F. At this temperature it will become necessary to operate the dehumidifying coil below freezing temperatures in order to reduce the relative humidity to a reasonable valve. Frost on coils usually will appear.
I would imaging that the humidity is already lower than the dehumidifier could get it down to. that's why it reads "Lo" on the display.
Jan 10, 2011 | Haier 45-Pint Dehumidifier
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Jan 09, 2011 | Haier DE45EAL Dehumidifier
Amana 45 Pint Electric Dehumidifier - D545E Logo
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
