Question about Whirlpool RBD305PD Electric Double Oven
Can't get self cleaning cycle to start - Whirlpool RBD305PD Electric Double Oven
Spectra oven. It was going through a self cleaning cycle and was shut off partially through that cycle. Now the door is locked and won't open up. Help!
Door lock has failed to open after cool off start oven into self clean again leave on for a 1/2 min. then cancel self clean motor for self clean should return to normal or lock switch need replaced need a model # on were lock motor is located
Jan 30, 2017 | Ovens
How do I operate my self-cleaning oven..no manual..
Thank you for your post, Pattie Cromie!
I see that you would like to operate self-clean on your Frigidaire range and you do not have the manual. Typically, to start self-clean you would need to push the button labeled "Self-clean" and make sure there is nothing inside the oven before starting a self-clean cycle. Also before starting self-clean close the door because of the temperatures that are created within the oven the door needs to be closed and locked. I hope this has been beneficial. -Matt
Oct 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
Started to self-clean, locked the door, etc. Had
Hi.
The appliance door is probably locked in consequence of the self cleaning cycle.
Unplug power cord, and allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 03, 2010 | GE Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Self clean
Usually the oven has to be locked closed with a handle on on the front door. This will activate a safety mechanism that will allow the cleaning cycle to start. If the safety switch is malfunctioning or the door is not closed properly, the cleaning cycle won't start.
Apr 20, 2008 | Ovens
Whirlpool RBD305PD Electric Double Oven Logo
13 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
