Question about Olympus Stylus 7010 Digital Camera
How to download pictures from my olympus stylus 7010 to my computor
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such a Picasa ( http://picasa.google.com ).
Posted on Apr 16, 2014
jaballou
  • 63 Answers
SOURCE: olympus Stylus 790 sw
Boot up computer. If running WinXP or later, plug USB into computer and camera, turning on camera. If camera not recognized by computer, then you will have to reinstall the original software for the camera, especially the driver. If you don't have the disks, you can download the software & drivers at:
http://www.olympusamerica.com/cpg_section/product.asp?product=1314&fl=15
Good Luck and Best Wishes!
Posted on Dec 16, 2008
  • 919 Answers
SOURCE: picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Posted on Apr 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: My olympus stylus 7010 lens is jammed and it wont
If you've recently dropped the camera you may have lens damage which is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 22, 2009
SOURCE: Olympus 7010 shuts down in picture mode - not a battery problem
I will tell you how I did it for the same price you were going to charge me for a solution. To ask how I did it once I found a solution without a fee goes against your business model.
Posted on Dec 29, 2009
  • 411 Answers
SOURCE: Olympus Stylus 7010 won't work in any mode except
shutter of the lens failure,take to a camera tec.
Posted on Mar 07, 2010
How do you take pictures on sd card instead of inernal memory on Stylus 7010?
With no card in the camera, go into the menu and find "format" (called "initialize" on some cameras) and follow the on-screen instructions to erase the internal memory. Then insert your card and enjoy.
Sep 16, 2011 | Olympus Stylus 7010 Digital Camera
I have a olympus 7010 digital camera. everytime i try to turn the camera on, a orange light flashes and turns off. i've tried charging the battery numerous times.
The Olympus Stylus 7010 has a rechargeable lithium ion battery that will eventually wear out-- your battery could be at the point where it does not hold a charge any longer.
Have you previously noticed a degradation in battery life? If so, you can try replacing the battery or connecting the camera to a constant power source (like an AC adapter) to troubleshoot.
Mar 04, 2011 | Olympus Stylus 7010 Digital Camera
The card access lamp on the olympus stylus 7010 blinks and then the camera powers off. What might the problem be?
Does it work in picture review mode? If so try turning the camera off and pushing the lens assembly in towards the body of the camera, otherwise, is the battery charged? Does anything come up on the screen?
Jun 27, 2010 | Olympus Stylus 7010 Digital Camera
My Olympus Stylus 7010 was working fine until yesterday, screen has warning sign saying Write protect
wen i bought my olympus stylus 7010 the number of pictures that can be save was 9999 and wen im taking pictures it doesn' tchange but after saving at least 1000++ pictures there are only 1800+++ remaining memory.. how can i have the same 9999 memory???
Jun 27, 2010 | Olympus Stylus 710 Digital Camera
How can I increase the total number of pictures to
Purchase at least one xD-Picture card up to 2GB in size. Or you can use microSD and microSDHC cards using the supplied adapter.
The number of pictures you can store depends on the size of the card, image resolution, and other factors. Obviously, with more cards you can take more pictures.
Mar 19, 2010 | Olympus Stylus 7010 Digital Camera
Dec 28, 2009 | Olympus Stylus 7010 Digital Camera
Olympus Stylus 7010 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
