Question about Mtd Garden
Honda woodpliter engone what type of oil - Mtd Garden
Engine code p2138
this is limp mode when this happens again take it to a shop/dealer telling them what is happening and have it checked out.
Aug 21, 2014 | 2006 Honda Accord 2.2i
Gear oil for 2004 honda crf 100
Fuel and ignition Sparks per cylinder: Fuel supply system: Carburetor Ignition type: Digital CDI Funnel diameter: 0.87 inch Compression: Engine mounting: Transverse Lubrication system: Wet sump Gear box: Manual 5-speed Clutch: Wet, multiple discs, cable operated Final drive: Chain Spark plug pipe type: NGK, CR7HSA Motor oil: Synthetic, 10W/40 Starter: Kick-starter
Jan 11, 2014 | 2004 Honda CRF 100 F
Broke the plastic gear inside
You did not say engine make or modell number (i.e. Honda GC160). A great place for parts is Presure Washer Store and Small Engone repa
Oct 23, 2012 | Garden
What type of oil do I use for a 1993 Honda XR 250? How much oil do I put in it?
I use semi-synthetic 20W50 and change the oil every 3500-4000 km.
I do the filter at the same time.
Oct 09, 2012 | 1993 Honda XR 250 R
What type of oil best for 1997 750 honda magna and how much
Your motorcycle comes from Honda usually with 10w-40 mineral base motorcycle oil. You can use any oil that is JASO MA certified motorcycle oil. 10w-40 for cold climate. 20w-50 for warm climate/touring. Car oils use different additives and may cause scoring in certain types of cam bearings. Do not use any oil that says " Energy Conserving " on the label . It will shorten the life of your wet clutch and transmission gears. If you choose Synthetic oils, they will help your bike run cooler and shift easier. Shell Rotella T and Rotella T Synthetic 15w-40 are inexpensive JASO MA oils. You will need 4 quarts of oil, an aluminum drain plug washer, and a filter. Pour in 3.4 quarts , run the motor, and check the oil level . Top up as needed.
Feb 23, 2011 | 1997 Honda VF 750 C Magna
What type of oil is best for a 2006 honda odyssey??? Tks
2006 HONDA ODYSSEY 3.5L 6-cyl Engine Code J35A7 2006 HONDA ODYSSEY 3.5L 6-cyl Engine Code J35A6
Engine Oil Grade 1......API* All TEMPS......5W-20 synthetic oil or conventional. Brand name you preference. Fram oil filter Part #PH7317 Honda oil filter part #15400-PLC-003 or 004
CAPACITIES: Engine, with filter..........4.3 liters After refill check oil level. Torque Oil Drain Plug.....29 ft/lbs
Jan 24, 2010 | 2007 Suzuki XL-7
Where is the starter located on a 2004 impala 3800 series
follow the positive wire from the battery to the starter. It should take you to the frontof the engone just beside the oil pan.
Jan 14, 2010 | 2004 Chevrolet Impala
For a honda 125 cbr how often do I change the oil and what type does it need?
oil change: every 1000km
oil type: silkolene comp 4 10w/30
quanity oil: 1000mls
Nov 03, 2009 | 2005 Honda CBR 125 R
Garden Logo
16 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
