Question about Tappan TGF320 Gas Kitchen Range
I am having a problem with the oven in my tappan gas stove. It will heat up but after awhile it cuts off. What can i do to fix this?
  • 82 Answers
Before starting, pull racks out of the way and remove bottom panel of oven. there are two knurl screws in the back, they will accept a flat screwdriver if you need it. Turn on the stove and watch the ignitor, it should get very bright almost white. If it just gets red that is most likely the problem. very common in gas ranges
Posted on Jun 18, 2009
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
Oven will not light
Your ignitor is going out and is to weak to open due to saftey. Replace the ignitor for the fix.
Phil
Apr 11, 2009 | Tappan TGF657 Gas Kitchen Range
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Oven makes an exploding sound when put on "bake" smell of gas
sounds like the oven valve is leaking slightly. just as a precaution i wouldn't use it till you can get a repair man out there.
Jan 02, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
149 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
