Question about ViewSonic Computers & Internet
Monitor intermittently goes black for a few seconds
bammbammfran
  • 159 Answers
SOURCE: RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
SOURCE: monitor goes black after a few seconds
I have the same problem on my Acer AL1711. The monitor was out of warranty so I opened it up and found one of the 1000 mf capacitor almost ready to pop. A 50 cents replacement from allelectronics.com fixed the problem.
Not recommended for anyone without experience soldering electronic components to PCB's.
Posted on Dec 29, 2008
dww0642
  • 79 Answers
SOURCE: SCREEN GOES BLACK AFTER A FEW SECONDS AFTER TURNING MONITOR ON.
More often then not, this is attributed to a failing Backlight Inverter. A Backlight Inverter, is a power board mounted below the screen that actually send power to the Lamp inside the LCD itself. Check to see, when it goes out if there isn't still some images faint in the screen. If this is the case take it to a local repair shop and have them order one and replace it. repair cost for this shuold be around 65-100 dollars.
If this helps, please rate my solution. Have a great day.
Posted on May 16, 2009
  • 597 Answers
SOURCE: my screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Posted on Jun 02, 2009
graemevm
  • 519 Answers
SOURCE: ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Posted on Jun 12, 2009
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Dell monitor goes black for a few seconds
The monitor has intermittent power supply failure.
Nov 25, 2013 | Computers & Internet
Monitor stays on for a few seconds then goes black
could be your wires or your moniter itself check those replace the wires and see what happens if it doesnt work just pm me
Feb 26, 2012 | Dell E173FP 17" LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
My screen goes black after a few seconds
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Computers & Internet Logo
23 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
