Question about Frigidaire FGF326AS Gas Kitchen Range
Fridgidare FEF326FSB oven will not work ? - Frigidaire FGF326AS Gas Kitchen Range
My Fridgidare gas stove model FGF348KSG trips the GFI when I try to turn the oven on.
Sounds like a dead short, you probably need to call the factory. Is it new? Has it always done this?
Jul 20, 2014 | Ovens
We have a Fridgidare stove, model #FGF378WCCB. It was working fine, then one morning, the oven stopped heating - it will only warm up to about 125 degrees. Do you think it might be the thermostat? Or...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | Frigidaire Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Error message F7 on my oven
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the (ERC)= Oven control board
Sep 14, 2009 | Ovens
The clock on my fridgidare oven is making a grinding noise. When the oven isn,t even being used. model # REG533MD-2
You have a failing clock motor. It "was" available as part of an entire clock assembly only, but the part has been discontinued.
Apr 28, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Moisture developing between the glass on the ovendoor
when the oven comes new ,,you must burn the coating of for about an hour..a form of food grade rust proofing..let unit bake at 400 for 55 to 65 minutes empty
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FGF326AS Gas Kitchen Range Logo
24 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
