Question about Whirlpool GEW9250 Electric Dryer
Dryer not drying water inside drum
Dryer was running for more than 3 hrs ,clothes were saturated with water with standing water in bottom of dryer
  • 883 Answers
SOURCE: Cleaned vent hose, dryer still taking forever to dry clothes.
you have a family of squirrels living in the rest of the vent tube which is leading outside...check vent outside. I once had flying squirrels come into my house through the dryer vent! My dog had a kitten.
Posted on Jun 04, 2007
aborcass
  • 2651 Answers
SOURCE: gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Posted on Feb 12, 2009
  • 1294 Answers
SOURCE: Washer has standing water left in the bottom
Can be helped here:
http://www.fixya.com/support/t1928312-door_front_end_whirpool_duet_washer_will
Posted on Apr 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Dryer has to be ran 2 to 3 times to completely dry clothes.
If your dryer is heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER (if it is different from the one you listed this question under), so I can determine how your dryer is configured. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Posted on Feb 08, 2010
I currently live in the midwest and today has been an extremely humid day (90 degrees+ and 84%+ humidity). I used our LG gas dryer (Model # DLG2241W) earlier this weekend and it worked fine. Tonight, when...
Water in the drum anytime after drying a load of clothes is not normal.
Was the load prior to you having found the condensation fully dried? If not, check for lint in the vent system and make sure that air is coming out of the vent (the flap or louvers on the vent cap should open fully on a short vent line). Even so, this would not account for a small amount of standing water in the drum.
The first thing that came to mind was outside air being drawn in through the vent. If you have air conditioning and a well-sealed house, the warm, moist air hitting the cool drum (in a relatively dry atmosphere) may cause condensation. Check the outside vent to ensure that the vent cap flap (or louvers) is (are) closing all the way. Convection or air flow from the basement to a vent fan in an upper level might cause this.
Please let me know if I can help further.
Jul 18, 2011 | LG Dryers
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 22, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Dum turns to fast for cloths to tumble, 2 hrs. to dry!!
don't know about the drum turning to fast, but the two hours to dry I do know. Disconnect the vent tube and dry a load of clothes, as there is a restriction in your vent tube. You will need to clean the tube out with a vacuum or leaf blower, you may want to clean the inside of the dryer out,also. Good Luck Tim
Jan 06, 2011 | Maytag Neptune MDG9700A Gas Dryer
The dryer makes a screaching noise when running. It still has been drying our clothes, but the noise isn getting increasing louder. The dryer is only about 6 years old. Could this be a belt related...
the noise can come from 1) something stuck between the tub and the felt. 2) bad roller / axel two in the back 3) bad idler pulley 4) wore glides ( in the front bottom)
Sep 27, 2009 | Amana Dryers
Inside of my maytag atlantis electric dryer...top layer is erodin
I WOULD NOT WORRY ABOUT THE FINISH COMING OF EXPOSING ANYTHING TOXIC. WHAT COULD HAPPEN IS THAT WITH TIME, THE DRUM MAY RUST AND TRANSFER IT ONTO THE CLOTHES. DEPENDING ON ITS CONDITION, IT SEEMS NEW ENOUGH TO WARRANT INSTALLING A NEW DRUM. I DONT KNOW IF A COATING OF PORCALINE SPRAY PAINT WOULD STAND UP TO THE CONDITIONS IN THE DRYER BUT IT MAY BE WORTH A SHOT AS I DONT KNOW OFF HAND WHAT A DRUM SELLS FOR.
Jan 23, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
Whirlpool GEW9250 Electric Dryer Logo
15 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
