Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile is not cooling and not making Ice too.All the fans running continously.
  • 1 more comment
  • Raph Lal Jun 18, 2009
    Yes the compressor is running and the fans are blowing also. The coil is clean too.
    Yes the pies around the compressor is NOT cold at all
  • Robbie Daniels May 11, 2010
    Is the compressor running?
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
mnv.m
Posted on Sep 29, 2010
GE Profile French door not cooling 70degrees
The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
in other words is there ice frozen all inside if so unplug and take a hair dryer and melt the ice thouroghly
GE Profile French door not cooling Google Search
Feb 04, 2018 | GE Refrigerators
I have a GE Profile side by side refrigerator. It has not been cooling very well, it stays between 38-41 degrees. also the ice maker doesn't make a lot of ice and the cubes are smaller in size.
Ice maker want work if freezer bus not around 0F. Are fans running? Is condenser coils clean? Is there any frost build up on inside back freezer wall?
Nov 06, 2017 | GE Refrigerators
My GE profile performance refrigerator is not as cold as it was
is the evaporator fan working, which normally make the food compartment cool.Are the cooling passages clear, if the fan is not functioning, it will create and ice build up which then needs to be defrosted by shutting it down or with a hair dryer or heat gun.
Jun 08, 2014 | GE Profile PSW26P Stainless Steel Side by...
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
We have a GE Side by Side Profile refrigerator and the freezer, at it's highest setting, can't keep ice cream frozen and the ice maker only puts out about 8-10 dumps in a 24 hour period. The model is...
Sounds like your coils are dirty which will cause inadequate cooling due to reduced heat exchange at the coils. Also check to make sure fan is running (next to compressor and should be running when compressor runs). The fact that your ice maker makes ice at all suggests that compressor runs, therefor no freon problems. Problem should be easily fixed with correct diagnosis. Hope this helps.
Dec 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Ge profile refrigerator is making a loud fan noise what is causing it?
Ice is built up and hitting the fan...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 27, 2010 | General Electric Profile PFSF5PJX Bottom...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Jun 10, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
123 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
