Question about Microwave Ovens
SEIKI LED TV WILL NOT POWER ON - Microwave Ovens
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
Microwave will not power on no led
These can be repaired economically.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | Frigidaire FMV156DC Microwave Oven
My microwave power is ok, led light ok, but dosen't work what problum?
check the door switches....i had an over the oven micowave with a bad door switch....thing is the switch cost 35.99 online and i bought a counter top microwave for 39.95 at walmart
Jan 31, 2012 | GE Microwave Ovens
I have an Iceline ff47/32 model fridge and would like to find out how much power it uses over 24h period as something is killing us in a 1 bedroom apartment.Our daily usage comes to 8kwh which is...
I have this same make and maodel fridge and it was doing the the it was always on and using around 3kw a day so went and bought a new one this new one uses less than 1kw a day its a big outley buying a new one but worth it in the end. i hope tis helps
Jun 04, 2011 | Microwave Ovens
11-30-2010 I need the user manual of Amana Mictowave model RS560W . Kindly assist. Thanks. Rgds Alon Felz The real problem: After heating the food (in a certain time selected), a beep sound should be heard...
In order to solve the problem this is what I did (with a help of Mr. Hilik
@ www.microgal.co.il)
1. Unplug the power cable 220Vac from the wall outlet.
2. Make sure or the clock led is "off" and screen is dark
3. Plug again the power cable 220Vac
4. Nothing comes "on" on the led screen
5. press on the digit "zero" (0) and you hear a beep signal
6. Take a glass filled with water press on the digits "1" and then "0" and
then "start"
7. After 10 seconds the beep signal will come on again.
8. Note: this kind a phenomena appears after voltage cut off when there
is a need to lift up again the handle on the voltage breakers . FYI.
Jan 30, 2010 | Microwave Ovens
Our microwave suddenly stopped operating.
Inside is a fuse. It is probably bad.
Jan 19, 2010 | Microwave Ovens
Microwave works fine, but the LED display is not working
Then chances are it can be repaired without having to buy a new board. I would suspect a connection or power component on the control board.
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
For disassembly info, please see these links: http://www.microwavedisplay.com/safety.txt
and http://www.microwavedisplay.com/disassembly.txt
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 12, 2008 | Hotpoint JE740WY/GY Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
