Question about Maytag MDB8959AWS Builtin Dishwasher
Blon tal fuse
Keep blowing termal fuse. (3) in 5 months. why?
I have an 05 mazda 3 keeps blowing engine bar 1 fuse #35 in owners manual. replaced it once and car ran for ten min and died. now fuse pops instantly. is this a common problem? if so how do i fi
I had same problem with Nissan 4x4 took it done to auto elec he couldn,t find the short so he put in a resetting fuse so if it happened sometimes it would not blow fuse but reset, but that made no sense so after a month I worked out what was causing it.The alternator had a bear wire in side that touched other wires when driving over bumps so it was shorting out ignition and petrol pump fuse, so got another alternator from the wreakers and it never happened again apparently its common. seaya Neil
May 05, 2014 | 2005 Mazda 3
I have a 2005 cavilier..it keeps blowing the main 30amp fuse when the ac is turned on..any help
you need to inspect all AC WIRING, to find the SHORT, thats causing the fuse to blow ! donot put another fuse in until you locate the shorted condition, ( bad connection, frayed wire, bare wire touching metal along this circuit, you might have a bad switch, your ac has two switches under hood, one @ high pressure side and one @ low pressure side. and your main control switch, check all wires & connections
Mar 11, 2013 | 1991 Chevrolet Cavalier
Keep blowing fuses for the wipers, have replaced
Your wiper motor is about to go out, if it hasen already, wiper motor pulling to many amps will cause the fuse to blow.
Dec 09, 2009 | 2003 Hyundai Accent
3 amp fuse in sat nav power lead keeps blowing
possibly a spike through the ciggarette lighter plug, try putting slightly larger fuse in ( 4 or 5 amp )
temporarily and see if it blows the slightlty larger fuse. if it does it's more likely to be something wrong with the ciggarette lighter socket if it doesn't blow the fuse it's more likely to be the power supply. Ebay for another one perhaps ??
Apr 13, 2009 | LG GPS
Ovrer heated now have water coming out exhaust
ceck the engine oil if it is a milky white colour you have blon the head gasket
Jan 08, 2009 | 1997 Mercury Cougar XR7
Infiniti I 30 will not start
I am assuming the fuse was not an issue before replacing the starter. You probably pinched a wire with the starter when you installed it. Take the starter back out and inspect the wiring harness, also see if the fuse blows when the starter is removed.
Nov 13, 2008 | 1997 Infiniti.5 J30
TV KEEPS BLOWING FUSES
means you have a part that is dead shorted after the line fuse, usually a bridge diode, regulator IC or possibly the Horizontal output transistor. Not really something a non tech will be able to find, a volt Ohm meter is required as well as soldering equipment.
Nov 27, 2007 | Panasonic CT-36G34 36" TV
Maytag MDB8959AWS Builtin Dishwasher Logo
21 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
