Question about Hoover Zen Whisper Multi-Cyclonic Canister Vacuum
Hoover zen canister vacuum won't turn on
I turned it off between rooms and it won't turn back on. The canister has been emptied, it was given time to cool down, and it still won't turn on. We've had this thing for only a couple of months.
SOURCE: My 2month old hoover bagless stopped working completely!
I may have figured out a way to make this thing work. If you find that the problem is the flimsy, floppy piece of plastic that I mentioned above, I think that the thing to do is figure out a way to make the narrow sticking out fin-like section that activates the switch wider. I think what happens is that fin slips over to one side or another and then does flip the switch. What I just did is cut a hard rubber washer into two half circles (or approximate half circles) and attached those on each side of that fin. So now I have a nice wide switch activator. I attached the pieces with exterior mounting tape. I imagine that some sort of adhesive could be used too, as long as it is not something that would dissolve the plastic.
Posted on Apr 08, 2007
  • 4 Answers
SOURCE: Hoover Wind Tunnel ON/Off Switch
Replace the rocker switch inside the handle. Part #28161067, it's about $2.50.
Posted on Jul 19, 2008
galati2k
  • 281 Answers
SOURCE: The vacuum turns on, but the thing with the bristles doesn't spin. Help?
no it can't be bypassed the motor is dc.the circuit board converts it from ac to dc
Posted on Apr 29, 2009
  • 5 Answers
SOURCE: I have no suction with my Hoover Mach 5 vacuum.
I had a similar problem. Two things to try. There is a lock symbol on the canister you need to ling it up with the mark on the top (the silver part has a line on it). It can be assembles 3 different ways. Also I over looked the sticker in the back of the canister compartment indicating a filter in the top of the canister compartment. There is an orange lever there to release the filter. Hope this helps.
Posted on Jun 18, 2009
SOURCE: hoover fusion plus cyclonic upright vacuum
While I'm having a different problem, the problem you guys are experiencing can easily be fixed by cleaning the two internal filters. My vacuum did the same thing, just stopped running mid-stream. Remove the main filter cup. Look inside the cavity of the vacuum and you'll see a grey bar at the bottom of the cavity, pull this up and you'll find the first of two washable filters. Just rinse it under warm water squeezing as you rinse until the water runs clear. The roll the filter in a few paper towels or towel and unroll, reroll until completely dry - should only take a few minutes. Then, look in the same cavity except up top there is another filter which seems to be hidden. The back wall of the inside cavity will guide you to these filters as well. You will be amazed by the difference cleaning these will make in the suction power of your vacuum. Also, if you remove the belt cover and clean out the hose in this area it will improve suction as well. Hope this helps. Now, if I could just get the darn belt back on mine. First belt smoked and popped. Bought replacement belt, smoked and popped within seconds... HELP!!!
Posted on Aug 11, 2009
How to empty canister hoover 18v stickvac
twist the container anti clock wise 1/4 turn and it comes off
arrow directions on body of the unit
Clue here
following problems under warranty , I took mine in for repairs and found that the design fault did not allow for the section from the head to the canister blocking up which resulted in an over heated motor
The fix is a redesigned head that has a removable section that allows access up the suction tube to the canister for cleaning of the small tube section
indications are --doesn't appear to have enough suction
Talk with your hoover service agent and consider replacing the old head with the new model
Apr 13, 2018 | Hoover Vacuums
We have a dirt devil that when the canister is engaged, it no longer has suction. The canister is empty. Thoughts?
you turned the switch to blow instead of suction
remember them days .. no .. i do
Jan 12, 2015 | Hoover Vacuums
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Light keeps flashing on top of canister of my Hoover Wind Tunnel but I emptied and cleaned it well. It sounds right when I turn it on then it goes into this sound like something is stuck but there...
sounds like a possible plug ,then when you first start it up the plug gets stuck a gain.
try taking hose off the unit and running water through hose .if water flows good ,check and see if lid is secure when closed.
Jul 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
Mar 19, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover vacuum turned off and wont go back on
Generic problem for all Vacuums
Hoover vacuum turned off and won’t go back on
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
Not knowing the model number – or if it is a canister or upright --- you may have a defective switch and would need to replace it – check with you local vacuum cleaner dealer in your area or in the yellow pages or call the Hoover Co for further assistance
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 21, 2008 | Vacuums
Hoover Zen Whisper Multi-Cyclonic Canister Vacuum Logo
223 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
