Question about Car Audio & Video
Need to know what wire is what on a kenwood eq
2 Suggested Answers
Ganx
  • 113 Answers
SOURCE: KENWOOD 9-BAND EQ DOES NOT POWER ON
Hi try earthing the chassis of the unit as well to ground with a wire. Sometimes units have to grounded all round. Check the inline fuses also to be sure
Best of luck
Posted on Jul 25, 2009
I have a velodyne sub woofer needs amp power source I have a kenwood eq and a sony reciever trying to figure out how to hook it all up right
So, you don't have a powered Velodyne sub (with a built in amp?)
Without model numbers - I"ll guess that there are speaker in and out connections on the back of the sub.
You simply connect the left and right speaker wires from the receivers to the subwoofers input speaker wire connections.
Then connect your main speakers from the sub's Out (or "speaker"} connections so that the sub is in line with the speaker path.
Use the sub's crossover settings on the back till you hca a seamless blend of the sub to the speakers where it is hard to tell you have a sub other than you your music now has deeper bass.
Why do you need the Kenwood EQ? This is not a necessary piece as nobody really knows how to use it properly and it realy complicates how you use your system. Flashing lights look cool though, right?
If you really must complicate the operation of your system then connect the Tape output of your receiver to the tape input of the Kenwood EQ, Then connect the Tape output of the Kenwood EQ to the Tape input of your receiver - assuming your receiver even has tape ins and outs.
You can engage the Kenwood EQ by inserting it into the audio path when you select the appropriate Tape input as the source on your receiver.
Hope this helps.
May 31, 2014 | Audio Players & Recorders
Hook up kenwood ge-1100
2 stereo rca cables tape out to line in on eq, line out from eq to tape in on receiver. press tape monitor button to use eq, turn off tape monitor for direct. some receivers also have a dedicated I/o for eq, you just need to remove the jumpers and install in that loop (out to in on eq out from eq to in on rcvr}
Mar 16, 2014 | Kenwood Ge 1100 Graphic Equalizer
Cant hook up eq 2 kenwood vr 505 reciever
on the reciever connect patchcords from the tape out to the line in on the eq than line out from the eq to the tape in on the reciever --when you turn on the tape monitor button then the eq is engaged --enjoy
Sep 08, 2010 | Kenwood Audio Players & Recorders
How to hook up a equalizer
i believe you need to be running an aftermarket amplifier to use this E.Q. does it only have RCA inputs and outputs on the back of it? if it does, you'll need to run the rca's out of the radio into the E.Q. then run the rca out's from the E.Q. to the inputs of your amplifier. and of course there's probably a constant 12v, a switched 12v, and a ground you'll have to wire up.
Feb 17, 2010 | Kenwood KGC-4042A 5-Band Car Equalizer
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Power unit on test for Kenwood kgc 7043
should not need the head unit.open up unit and start testing continuity along wire an board.possible break in connection.
Feb 24, 2009 | Kenwood Car Audio & Video
CONNECTING
you can do it passive. no idea with your ampli, but if it does have a bridge then you can hook your eq there, series. if it doesn't have then via tape monitor 2 of your kenwood.
onkyo recvr tape 2 record to - kenwood eq in
onyo recvr tape 2 playback - kenwood eq out
that's all. if you want your eq to be active, then switch your reciever to tape2, all selected input in your reciever will by pass through your eq then back to kenwood. you dont have a function for tape 2 input then but your eq will have an extra input for tape, that you can use for your second tape, it will be active only if your reciever is set to tape 2. i hope you got it right.
post back if you got it done
red
Feb 10, 2008 | Audio Players & Recorders
Which wire is power and ground
generally red is the ignition wire, black is ground, orange is 12+ all the time, a yellow could be the same....it would be more helpfull if you would give the model number of the eq
Jul 13, 2007 | Kenwood KGC-4042A 5-Band Car Equalizer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
