Question about Boating
1995 200hp evinrude oceanpro only getting fire to one spark plug
    New Friend:
  • 4 Answers
Check the trigger it is doubtful that both power packs are bad move trigger around the stator and see if another plug fires if it does the trigger or optic eye is bad most likely the eye
Posted on Apr 18, 2014
I HAVE A 1978 EVENRUDE 35 HP NO FIRE TO THE PLUGS GREAT COMPRESSION???
evinrude 1978 -1979 have a capacity discharge ignition unit as the control for the spark system
it runs wires to an ignition coil
so I would be suspicious of that unit
check all connections for corrosion and bad connections
I typed in electrical schematics for 1978 evinrude out board engine and found a site --www.maxrules.com which in the list of schematics has 55hp 1977-1978
press on that and you get a schematics of the wiring diagram evinrude 1978-1979 55hp
now I am aware that you state that yours is 35 hp but if it has 2 cylinders then it is a fair bet that the wiring diagram will be the same
any way there are plenty of other sites that may be of benefit
Nov 26, 2015 | Boating
What is the correct compression for a1993 Evinrude 225 hp oceanpro
Most outboards should generate at least 100 psi. Most 2 cycle will go up to 120-130 psi. Compression readings are not real accurate on 2 cycle due to the oil in the gas or injected. What you should look for is a difference between cylinders. They should not be more than 10 lb difference.
Feb 20, 2015 | Boating
Got a50hp evinrude lark and it will not start but has spark
Does fuel get to the intake valve?-Check your fuel filtration,what color is the spark?If its reddish the machine will not fire,Bright blue-ish to white color spark is best,check the kill switch components,Just some ideas....
Sep 15, 2014 | Boating
Spark plug gap for 1990 evinrude express v6
The gap is 0.030
Pretty-much the gap for most of the motors in evinrude line-up during that era.
Sep 06, 2014 | Champion Spark Plugs Marine Spark Plugs...
1997 50 hp Evinrude won't fire
Take off the top & expose the magneto clean with a fine grit sandpaper that should get fire to the plugs if still no fire u may have.to replace the points
Jul 23, 2012 | Boating
1968 evinrude starflite 100 hp no spark
Some of those had a battery ignition with a short cap and rotor, and some had a magneto which reached down into the bucket. Both had points and condenser like an old car. The cog belt location was critical. 2 teeth off and it would not fire. the key switch was wired diferently for each ignition system.
Jun 19, 2012 | Boating
Engine turn over but will not start on 50 H P evinrude boat motor
Check- Do You Have Spark At The Spark Plugs?If Not Then It Could Be Stator Or CDI Unit Or Trigger, If Yes Good!
Have Carburetor ('s)Got Fuel In Them? ,If Not Clean Carb's.
If Both Are Correct It Should At Least Fire
Good Luck
Jun 06, 2010 | Boating
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
