The temp display on the unit is showing HI on both upper and lower compartments and the unit is not cooling
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
SOURCE: dual zone wine cooler left
Please can you give the model number of your Danby refrigerator
Thank You
SOURCE: I have a Danby Silhouette
The device works like a refrigerator ..and there for the thermostat is to blame that it do not kick in the compressor once that the temperature exceeds the one that you preset ..So the action to do is to change the thermostat and will work fine ..
What is the model number of your unit?
