Question about Jacuzzi Amiga, Soaking Bathtub with Integral Skirt - T705
Spa issues i have an in ground pool and when i turn the heater on to heat up the spa, it turns on but the water keeps flowing thru to the pool.
    Scholar:
  • 80 Answers
Is the spa inground also? If so you need to turn off the filter return at the pump and use the circulation pump only. this is only a best guess as I am unsure of the pump setup.
Posted on Aug 19, 2009
Model h100id banging noise when turned on shuts off
VERY low water flow!
Or... No water flow.
This heater as all heaters do, need to have sufficient water flow thru them, or else they Bang like this.
This then creates a problem, for future banging - due to lime up!
The minimal water flow gets so Overheated, that it turns to steam! The steam knocks and pushes the heater around, then the Minerals will precipitate out of the water and forcefully attach to the inside walls of the heat exchanger! Which will then drastically reduce the inner diameter of the exchanger making a much smaller passageway for water to travel thru! This is a major problem to remain this way. It will then need to be dismantled and de-limed to increase the holes once more, and allow a proper water flow.
May 30, 2015 | Hayward 100,000 BTU Pool Heater H100ID1 -...
How do I get my GL235 Solar Heating Panel (Goldline Controls) to heat. It is not heating the pool even though the control lights indicate that the heater is on.
If water is flowing thru the panels/collectors, (look to see if the valves are opened to allow water to the collectors) if the water is flowing and it is flowing through the collectors/panels, then the water is being heated!
If you are saying the controller is set for solar operation and the sun is shining, and there is a "Demand" for heat or a "Call" for heat, and the Valve is NOT turning to allow the water to the panels, then you have a problem with either the Hayward/Goldline Controller or the Valve Actuator.
Good Luck
Nov 15, 2014 | Pool & Spa
Why is my GL235 solar heater control panel not heating the pool. The heating light is on and the power light is on. What should we do.
Good Luck
Nov 15, 2014 | Goldline Solar Pool Control Package Gl-235...
Can the heat exchanger get calcium plugged on a Pintair pool heater
That's possible...but you would definitely notice the heater doing HIP HOP dance moves and making lots of racket - banging and clanging! And your heat exchanger would've melted and pool would probably empty out as it was flooding your equipment room!
because if there's 400,000 btu's of heat (Which IS a lot) being generated by the burner tray, under the heat exchanger, with very little water going thru it... What do you think the result would be???
Jun 18, 2014 | Hayward H Series Pool & Spa Heater 400k...
Why is the flame on but water not heating
check gas pressure if correct check heat rise you might need to slow water flow down
Jun 17, 2014 | Jandy Legacy Natural Gas Pilot Light Pool...
Spa has not been on for a year and now heater will not stay on. What's wrong?
Make sure there is water flow thru the heater when it is turned on. If there is low water flow, the heater will shut down.
If there is adequate water flow, then check your pressure sensor and insure it is engaging when there is water flow. If not, replace it.
If these do not resolve your problem, then check your thermostat.
Hope this helps,
Osko Pool n Spa
http://www.oskopoolnspa.com
Apr 10, 2013 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My heater rattles I took off the inlets and saw a piece of loose metal between the inlet and outlet
Thank you for posting your question here on Fixya.com.
That is the diverter plate and it should be welded into the header. It helps direct some of the water flowing thru into the heat exchanger to heat the water. If the weld fails the diverter can interfere with that flow and cause overheating or poor flow thru the heater which in turn can lead to the problems you describe.
Remove the inlet side hose once you have blocked the flow of water from the pool and you should see the diverter in the inlet. If you can move it then it is broken and needs to be fixed back in place or the whole heat exchanger needs to be replaced.
If you can weld then tack in back in place. If not a local rediator repair shop MIGHT be able to fix it or else you need to replace the whole heat exchanger assembly.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Sep 06, 2011 | Hayward 100kbtu Pool Or Spa Propane Gas...
I have a hayward H100ID above ground pool heater. Recently the heater is making a rattling sound and the in and out hoses are bucking or pulsating. The water is still being heated but somehting does not...
The Hayward H100 has a diverter plate welded into the header that helps direct some of the water flowing thru into the heat exchanger to heat the water. If the weld fails the diverter can interfere with that flow and cause overheating or poor flow thru the heater which in turn can lead to the problems you describe.
If the diverter is not moving then your issue is likely an overall water flow one and the next place to look is the filter. Poor overall system flow may be enough to close the pressure switch telling the heater the pump is on but not enough to keep the water in the exchanger from getting too hot, again causing the symptoms you describe.
John
Aug 30, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Jacuzzi Amiga, Soaking Bathtub with Integral Skirt - T705 Logo
94 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
