Question about Garden
McCulloch Trimmac 250 recoil spring replament
dontbother10
  • 2220 Answers
SOURCE: broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Posted on Sep 05, 2009
dontbother10
  • 2220 Answers
SOURCE: Starter recoil spring reload, How?
If the spring is unwound.
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If the starter cord needs a pretension, this works quite well.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 27, 2010
dontbother10
  • 2220 Answers
SOURCE: How do you re-install recoil spring
Possible answer 1 (a very good description of tension adjustment is on the video in answer 2; about 1:20 into film):
Possible answer 2:
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 07, 2010
  • 5 Answers
SOURCE: i need a manual for my mcculloch trimmac 210 does
you can go to:
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
and click where it says
Download the complete user guide
before you can download the manual (11 pages), you'll be asked to rate the trimmac 210.
Hope it helps
Marcos
Posted on Jun 16, 2010
micromatikal
  • 2777 Answers
SOURCE: i need a user manual for a McCulloch TrimMac 210
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://micromatikal.dlinkddns.com:8000/cust/210.PDF
Thanks,
Tim
Posted on Oct 20, 2010
I need a works manual for a McCulloch TrimMac 210 strimmer. Where can I obtain one?
Try Googling (McCulloch)(210)(manual) without parens.
May 02, 2012 | Garden
Whats the part # for the mcculloch chainsaw eager ****** MS 42 recoil spring
YOU CAN HEAT THESE UP WITH A TORCH AND MAKE THEM WORK AGAIN..SEARCH EBAY EAGER ******, THIS GUYS GOT LOTS OF STUFF CLICK HERE TO SEE
CLICK ON THE YES IF I WAS OF HELP .. JAY ..FLORIDA
Jun 13, 2011 | McCulloch Garden
Can anyone help provide english instructions for McCulloch TrimMac SL Petrol Strimmer. It has every language except english.
This should be a help:
http://www.4mcculloch.co.uk/images/mediator/1282/moen2006_545097742en.pdf
I scrolled down a couple of pages and it all seemed to be in English -- though there are other languages there as well.
May 26, 2011 | McCulloch Garden
Mc culloch trimmac 250 LS triming head is only rotating very slowly and stops when i go to strim there does not seem anything wrong with the cable between the engine and the cutting head
It certainly sounds like an issue with the flex drive, or maybe where it fits into either the gear head or the clutch drum, it may have rounded the inner connection where the flex drive fits into.
May 01, 2011 | McCulloch Garden
Spring on recoil starter broke after using generator third time. now mcculloch says recoil starter is not available.have to purchase entire starter housing assembly for $105.00
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Sep 13, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Ratio of oil to petrol for a McCulloch Trimmac 240
normal mix for pet/oil is 50:1 but it depends on the oil you use
Jul 11, 2010 | McCulloch Trimmer Plus Attachment: Add On...
I need a manual for my mcculloch trimmac 210 does any one know where i can get one?
you can go to:
Hope it helps
Marcos
Jun 16, 2010 | Garden
How do i get the pull cord spring back in on a
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Nov 22, 2009 | McCulloch Garden
How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Aug 31, 2009 | Black & Decker 14" Grass Hog Xp...
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
