Washer sharp ess119
Error codes c0 or c1
barkencoa
  • 3463 Answers
SOURCE: getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Press( stop/cancel) to clear the display.
Hope this helps
Posted on Nov 24, 2008
  • 636 Answers
SOURCE: Kenmore Elite Calypso washer with C1 error code
Have you tried unplugging it for a couple of minute?
Posted on Aug 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE Model #110.27087604. My
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Sears Elite Calypso Washer shows a C1 error code
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code c1 of ca
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
What is error code C1-14
C1 14 MAIN CHARGER TROUBLE (COLOR)
You might be able to clean the charge wire.
https://www.sosnfl.com/sharp-mx-c312-error-codes/
May 07, 2016 | Sharp MX-C312 Multifunction Printer
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
What does error code 155 mean
This is not error code. If a fault occurs on your device it will be displayed in hexadecimal code for example:
Newer models: i10, i20, i30 ....... i90, iA0,.............iF0
Older models: A0, A1 ........ A9, AA, Ab,............. Af
or C0, C1 ........ C9, CA, Cb,........... Cf
Because that I believe that the digit number "155" that you see on the display means the duration time (minutes) of selected program. Also see in user manual how to cancel selected program and choose new one.
Dado
Nov 04, 2014 | AEG 23 in. Favorit 50750Vi Built-in...
Eroor code on Sharp ARC260M copier
Please report the error code e.g., F1-47, C1-30, H5-01 and so on.
Jun 16, 2013 | Sharp Office Equipment & Supplies
Kenmore Elite Oasis HE Model #110.27087604. My washer had an error code "ld". I removed the hoses from the pump and discovered loose change in the pump that was probably jamming the impeller. I removed...
Jul 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
How to clear error code c1-00 on my sharp ar337
Main charger unit above drum has problem, clean it.
Jun 28, 2010 | Sharp Office Equipment & Supplies
Codes
Hi
Here's the codes:
TELEWEST (5A 01)
00 = 40 7B EC 04 95 56 68
01 = ED C1 B7 A0 6E B8 C9(new)
TW:
00 - C0 F6 61 87 91 F9 67 57
01 - E8 C9 E5 6E B0 49 53 F5
NTL:
00 - 7F CD 76 82 BB 22 0A C5
01 - 35 5E D6 40 6E AA 99 41
CW:
00 - D8 53 39 BD 3D CA 86 C1
01 - 27 77 A1 FC 8F 9D 34 76
NTL IRELAND:
00 - 9C 0E 3C 8D D6 73 80 28
01 - F2 46 B1 59 04 61 77 71
Jan 29, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Error code c1
Error code C1 indicates a problem with drive motor-thermal protector or the motor controller
may be due to overloading
Hope this helps
Dec 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Starview codes Telewest codes for london
Dec 17, 2008 | StarTech.com StarView SV211K 2-port KVM...
Getting error code c1
Hi
Hope this helps
Nov 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
