Question about Lexmark Xs736de All In One Laser Multi-function Printer Monochrome
296 scan error lock unlock - Lexmark Xs736de All In One Laser Multi-function Printer Monochrome
Why do I get an error message: Internal error occurred. Scan driver will be closed. Code:5,202,52?
Look at the bottom of the scanner and there should be a lock/unlock slider. Unlock it and see what happens.
If it is already unlocked then the drive/stepper motor or belt is bad.
Mar 27, 2015 | Canon CanoScan LiDE 25 Flatbed Scanner
Where is the sensor lock switch?
The scanner lock is situated at the left side of the flat bed scanner. switch it to UNLOCK.
Sep 04, 2014 | Oki Brand Oki MB480 MFP Multifunction...
Np code for alcatel 296
If you are searching for Np code for alcatel 296 ,then you can get it from the site OnlineGSMUnlock.com .You can get the code from the site by providing some basic information about the phone like the country and the network to which the phone is locked to .After providing this information you will get the unlock code via mail,using the unlock code you can unlock your phone to use it with any other GSM network of your choice.
Aug 04, 2013 | Alcatel Cell Phones
Canoscan lide 20 Error; Release the lock switch, detach the USB cable and reconnect. Scanner driver will be closed.
hi.. there is a lock under the scanner you need to unlock it... lock it to prevent damage while transporting...
Dec 16, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Where is the scan head locking switch
hi dear
Release the scan head locking switch.
The scan head locking switch is under the document glass.
If the switch is locked ( ), the machine will not operate. Unlock the switch
oke
cropp
Mar 19, 2008 | Sharp SHP AL1655CS Printer, Scanner,...
Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Mar 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error L1-00
Yes, ,there is a clear plastic round thing where the paper comes out uder the scanner that locks or unlocks the scan head. turn it to unlock.
Dec 10, 2007 | Sharp AL-1655CS Laser Printer
Lexmark Xs736de All In One Laser Multi-function Printer Monochrome Logo
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
