Question about NetGear Computers & Internet
Setup vegn2610 more secure
How to Setup to Norton 360 Security on Windows 10?
Hey,
Norton security is one of the best computer Security software.
Norton 360 Security is the best antivirus software for Windows 10. If you choose Norton 360, believe me, you did a great job.
Setup of Norton 360 security is very easy and same as other Norton Antivirus setup.
Things will become little difficult if you are installing it in Windows 10.
just follow some easy steps to set up Norton 360 Security
-Before Setup Norton 360 you need a Norton Account.
-open Norton.com/setup in your browser.
-create your own Norton account
-If you have Norton account then open it
- enter the 25 digit code key and hit enter
For more detail go to
www norton com setup Norton Activation Installation Norton Setup
I m sure it will help you.
Jan 03, 2018 | Norton Computers & Internet
Need hard drive password
You need to go to CMOS setup or BIOS setup. Follow these steps: 1. After pressing the power button of your Laptop, press F2 key until it display the CMOS setup menu. 2. Select the Security tab then it will open the System and HDD security. 3 Enter your security password on it. 4. Save your settings. Then exit.
Apr 20, 2011 | Dell Latitude D505 Notebook
I have a new TP-Link WR941ND router My new Toshiba laptop can see it on the wireless network but when i enter the secure key it tells me it can not join, even my new iPad2 can see it but can not join the...
Greetings - Most likely the router is setup with a certain security type, such as WEP or WPA of which there are several types each.
Your laptop and Ipad have to be setup for the same kind of security as the router then the security key will work.
If you setup the router you have to log back into the router settings and see what kind of security is setup and what the login password is. If you didn't setup the router the person who did has to tell you what the security settings on your devices should be.
Good Luck and Thank you for using Fix Ya.
Mikeywaf
Apr 10, 2011 | TP-LINK TL-WR941ND Wireless N Router -...
How do i set a password for it or secure it
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab near the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security mode.
7.Always select Security Mode as WPA2 PERSONAL.
8.Enter the key which you want to setup.
9.After changing the settings Click on the save settings.
Regards:-
Amit Awasthi
Dec 09, 2010 | Linksys Wireless-G Broadband Router
How can I create a secure code?
IN order for you to enable wireless security on your network you need to access the router setup page where you can setup all the settings for it including the wireless security
So to do that access the router setup page and once there look for a wireless portion on the setup page and from there you will be able to see the place to enable WEP or WPA I suggest you use WPA which is a much stronger level of security that you can use.
Dec 04, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
Security(wps) light not lit on router
You need to setup the wireless security ON on the router by loggin in to router setup page for that you need to connect the router with a ethernet cable with the computer or laptop and open the router setup page with router IP in internet browser, if you can tell me the model number of the router and brand i can give you step by step process to setup the security on the router.
on selecting the security as any apart from none the light comes on
Let me know if this will help
Regards
Nov 30, 2009 | Computers & Internet
How do i find my network key or create one for security?
Login to your router and check to see if wireless security is setup:
Use Internet Explorer and type 192.168.2.1 in the address bar.
Login using the password you created when you setup the router.
You can view the wireless security settings and retrieve the key.
If security is not setup you can enable it....directions here:
http://www.usr.com/support/5461/5461-ug/wireless.html
Mar 11, 2009 | U.S. Robotics MAXg USR5461 (738168036790)...
How do I make it secure on my mac I could not read the CD
You can manually setup the security. You can check this link on how to manually setup a security. You follow these steps.
1. use a computer that is wired direclty to the router. Open you browser and type this number in the address bar. http://192.168.1.1. no username and password is admin. say ok.
2. Once you are in the linksys setup screen, click on the tab at the top that says Wireless, make sure to set the wireless setting to manual setup and hit save settings at the very bottom of the page and once your back look at the top where you clicked wireless, right under that click on the subtab that says wireless security. Set the security mode to WPA-Personal. and on the WPA-Shared key box type the password that you want to use. (it should be a minimum of 8 characters)
Aug 17, 2008 | Linksys Ultra RangePlus Wireless Routr...
Bad Roomate
You can do that by accessing the setup page of the router.
You can follow these steps on how to change the name and put in a security.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router’s web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless.
NOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to "linksys", change it to something unique and take note if Wireless SSID Broadcast is set to Enable.
3698-009.png Step 4:
Click Wireless Security and take note of the current Security Mode.
3698-007.jpg If Security Mode is set to WEP:
NOTE: In this example, WEP 64-Bit is used. To know more about Wireless Security, click here.
3698-013.png If Security Mode is set to WPA:
NOTE: In this example, WPA-TKIP is used. To know more about Wireless Security, click here.
3698-015.png Step 5:
Click 3698-017.png.
Or you can go to this link. if you can see the images.
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
168 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
