Question about Brother MFC-8840D All-In-One Laser Printer
Won't feed paper through the adf to scan but it works to fax
Need to scan and email 5 papers from adf. it won't feed but scans from the glass instead
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: ADF not working
Open the document feeder and look for an obstruction.
Clean the roller and pad with isopropyl alcohol.
Also look for a switch actuator trapped down or knocked off.
Posted on Jan 04, 2009
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
Need user manual and software for a HP ScanJet 4p scanner
HI...................
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
  • LINK OF THE USER MANUAL IS GIVEN BELOW.............
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=25293&prodTypeId=15179&objectID=bps01187
  • LINK OF THE DRIVER IS GIVEN BELOW................
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=25293
Sep 23, 2011 | HP Office Equipment & Supplies
Copy off glass copy is good. copy from ADF copy is blurry
The problem is either dirty glass for the ADF which you can clean, or the ADF cannot feed the paper you are trying to scan through accurately. Most smaller all in one printers use the same scanner element for both the ADF and flat glass scanning so the fact that glass scanning is fine points to the two problems listed above.
Mar 29, 2011 | Office Equipment & Supplies
Paper jams when using the ADF. Canon IC D780
When using ADF
Note:
* Set a document on the Platen Glass if you want to scan it at optimum quality,
* The area (range) within 0.08"/2mm from the top edge if document cannot be printed since the machine cannot scan it.
*Do not load the following types of documents in the ADF. They will jam.
-Wrinkled or creased paper
- Curled paper
- Torn paper
- Paper with holes
- Carbon paper or carbon-backed paper
- Surface treated paper
- Onion skin or thin paper
- Photogragh or thick paper.
1) Remove any documents from the PLaten Glass.
2) Open the Document Tray.
3) Load the document in the ADF.
Load the document with the side you want to copy, or scan face up in the ADF.
4) Adjust the Doument Guides to match the document width.
Note :
Ensure that the edge of the document stack is in line with the Paper Size Mark imprinted on the Document Tray.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Nov 30, 2009 | Canon Office Equipment & Supplies
When making copies using the ADF, vertical lines print out on the paper. Doesn't happen when paper put directly on the glass.
The ADF works by moving the paper past the scanhead, on glass works by moving scanhead past the paper.
When you are scanning with ADF, the scanhead is parked in a particular position, under the glass. Just at one extreme end. Open the unit to te point that you are able to clean the lint, debris, lollipop sticks from this area. That should be it, since works otherwise indicates a good scan head.
Nov 02, 2009 | Canon ImageClass MF5770 Laser Copier...
ADF not working
Dec 20, 2008 | Brother MFC-8840D All-In-One Laser Printer
Canon MultiPASS F50 won't copy but will scan
Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
Oct 15, 2008 | Canon MultiPASS F50 All-In-One InkJet...
HP Office Jet 7310
chances are the feeder isnt feeding the paper at all, thats why you cant scan a single paper, try opening up the ADF and clean the feed rollers first, turn off the machine and gently rub the rollers again and again until you have a clean shot or surface, try this from thop to bottom rollers, please make sure though to insert uncreased paper and paper without eardogs on its leading edge, this could cause some delay upon feeding process
sometimes because it is exposed to dust, there is a tendency for the rolllers to slip, or you could be having a broken part that drives the feed rollers from your ADF.
Jun 30, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Brother MFC-8840D All-In-One Laser Printer Logo
20 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
