Question about Izzo Swami 3000 Golf GPS Unit Kit
I just got a swami 3000 and when I turn it on, it just says locating satellite. It counts back from 100 and then shuts down. Is this normal?
My swami 3000 wont hold a charge
stop taking all day to golf,it should last 4 hours if not get a new battery
Apr 26, 2015 | Cars & Trucks
Can i change battery in izzo swami 3000 price of battery
The battery is an "icr 14500" 3.7 volt 750 milliamp battery. Same size as an AA battery. It must have solder tabs on the battery. You will need a low power soldering iron to remove and install the new one.
Jul 11, 2014 | Izzo Swami 3000 Golf GPS Unit Kit
The case is: I shut my laptop " satellite a300 Toshiba" off by the button, and I did not wait it until shut down normally. then, every time I try to turn it on again it starts normally and...
That pointer is there to notify you that no operating system was found - Windows has been completely corrupted when you have shut it down while it was still working. Just reinstall it and all will be back to normal.
May 18, 2011 | Toshiba Satellite A300-ST6511 Notebook
Toshiba satellite shuts down by its self. and can be turn on back on right away.
go to control panel and locate event viewer. from event viewer select on system events and check on events that causes the laptop to shut down.
hope this helps . . .
Apr 02, 2010 | Toshiba Satellite A215-S5822 Laptop
Power light comes on,fan starts then shuts down nothing hapens but power light stahys on.
try draining the battery order to do this. batery should be taken out the laptop. power adapter is unplugged. press and hold the power button then counte 1 to 10 then release your finger after 10 secs. then press in again then count. do that for 3 times. plugged everything back in and monitor the status afterwards
Mar 06, 2010 | Lenovo 3000 N200 Notebook
Toshiba satellite A70-KL1 notebook shuts down
Scan the Computer using any latest updated anti virus program for any potential threat.
If the computer is not infected by any virus or trojan then you may also try performing System restore to the time when the Computer worked normally.
If the Computer keeps shutting down randomly after turning ON then the Power Supply Unit in the Notebook requires service.
Sep 15, 2009 | Toshiba Satellite A70 Notebook
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
SL 100 keeps restarting. Computer does not see it when it's hooked up.
I had to re-install Version 1.1 of My Sirius Studio from original CD that came with my Stilletto 100 as the most recent Version of My Sirius Studio did not recognize my Stilletto when I plugged the USB into my PC, when I re-installed Version 1.1 over the newer version, I shut down the Stilletto by holding down the power swith for 5 seconds then powered back up while holding down the Options and Display buttons at same time until the screen asked me to plug the USB cable into PC to recover. I did this and about 5 minutes later the the software/firmware was re-installed in my SL 100. I then plugged SL 100 into antenna and selected satellite radio, took about 1 minute to re-aquire the station ID's and Icons then I selected Sirius Hits 1 then everythings was back to normal, other than I lost all of my stored songs and recordings, but at least my SL 100 is operational again.
Jul 20, 2008 | Sirius STILETTO 100 MP3 Player
Sony TV shut down
Sony sets have internal diagnostics. Unless the ste is 100% dead, you should see the standby light blink in a pattern of count,pause,count... Please supply that count here and I can give you details about the problem.
May 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Vista Laptop immediatly shuts down after i pluck out the power cable.
It sounds as if the power pin (where the AC cord connects to the computer) has been damaged. The part to fix it usually runs under $10 but the labor is gonna set you back $100-200.
Because the connector pin is so fragile, the damage to the pin is caused by the day to day tugging and pulling on the power cord.
What you needed when you got the computer is a cable stay or cable retention device like the Jerkstopper. It takes up the strain when you yank or **** the power cord and minimizes the damage to the power pin. It's a very common problem with laptops.
Here's a short video that talks about the problem. . . .
Apr 20, 2008 | Toshiba Satellite 2410-S203 Notebook
Izzo Swami 3000 Golf GPS Unit Kit Logo
204 people viewed this question
Top Izzo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Izzo Optic Expert? Answer questions, earn points and help others
