Question about 98-01 Nissan Altima GXE SE Hood Panel Assy Steel NI1230151 F51009E030
Cylinder one oil on bottom of spark plug
Can ignition be timed if light oil residue still appearing on plug after replacing grommet and valve cover gaskets?
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Like the first answer .
your stem seals need replacing or rings.?
if you can get a mechanic to have a look for you ,
he can tell what's going on.?
Good luck.......
Posted on Mar 02, 2015
    Habit-Forming:
  • 95 Answers
The oil is either valve stem oil seals worn or piston rings, compression test the cylinders
Posted on Feb 16, 2015
  • CARPARTSDEPOT Master
  • 906 Answers
Yes you can still set the timing.
Posted on Jan 29, 2015
Need to remove valve cover on 2000 Camry Toyota
For the four cylinder engine:
  1. Remove and label all electrical wiring, connectors and vacuum hoses necessary to gain removal clearance.
  2. Remove the spark plug wires. Disconnect the PCV hose.
  3. Remove the four nuts and grommets located on top of the cylinder head cover.
  1. Remove the cylinder head cover and the cover gasket from the cylinder head.
  2. Discard the gasket and replace with a new one.
To install:
  1. With a wire brush or gasket scraper, remove all the old gasket material from the cylinder head and the cylinder head cover gasket surfaces.
  2. When the cylinder head surfaces are free and clean, apply beads of sealant to the cylinder head in the locations shown in the accompanying illustrations.
  3. Install the new cylinder head gasket in the cover. Make sure that the gasket seats evenly.
  4. Place the cylinder head cover with the gasket onto the cylinder head.
  5. Install the four grommets and nuts. Uniformly tighten the nuts in several passes to 17 ft. lbs. (23 Nm).
  6. Connect the PCV hose. Connect all removed vacuum hoses, connectors and electrical wiring. Connect the negative battery cable.
  7. Start the engine and inspect for oil leaks.
  8. Repair any leaks as necessary.
For the V-6 (3.0L) engine:
  1. Drain and recycle the engine coolant.
  2. Disconnect the radiator inlet hose.
  3. Disconnect the throttle and accelerator cables.
  4. Remove the air cleaner cap assembly.
  5. Remove the V-bank cover. Use a hexagon wrench to loosen the nuts.
  6. Label and remove all emission control valve hoses. Disconnect any wiring interfering with the valve cover removal.
  7. Remove the air intake chamber. This will gain you access to the back valve cover.
  8. Disconnect the engine wire from the left hand side, No. 3 timing belt cover, rear side and right hand side. Most of the wiring is secured by nuts and or bolts to the body of the vehicle.
  9. Remove the ignition coils, make sure the place them in order on a table so not to mix them up.
  10. Remove the 8 bolts retaining the valve covers and gasket.
  11. Clean the mating area of the valve cover and cylinder heads well. If necessary, scrape any left gasket from either surface.
  12. Apply seal packing to the cylinder heads and place new gaskets into position.
  13. Attach the valve covers. Uniformly tighten the bolts in several passes to 69 inch lbs. (8 Nm).
  14. Install the spark plugs in their proper locations, then place the ignition coils into place and secure.
  15. Attach all engine wiring be sure to secure each harness properly.
  16. Install the air intake chamber. Refer to Fuel System .
  17. Attach all emission hoses and wiring.
  18. Attach the V-bank cover.
Apr 15, 2014 | 2000 Toyota Camry
92 toyota camry running like on only 3 spark plugs instead of 4, oil getting on spark plugs on the passenger side seeing like black shut on the inside of hood on passenger side
Stop the oil leak. There are gaskets and seals for wherever it's leaking. Valve cover gaskets or seals on the cover if the plugs are recessed. Is the black stuff oil that gets splattered up there?
Spark plugs can keep firing even with oil around the base, but the cleaner the better. A clean engine runs a whole lot better and cooler than one caked in oil. Just don't try to pressure wash it or you'll have worse problems.
It would help you if you could isolate a non firing cylinder, find the one that's missing, I mean. There is a way to find a miss on a running engine by isolating a cylinder that doesn't drop idle speed when the plug wire to that cylinder is removed. But please have someone do it that has done it before. They will know what spark shock means, and how to avoid or mitigate it, or anticipate it-lol. Thatsa lotta voltage!
If you pull the spark plugs out, may help you find the bad cylinder: one will look quite different, may be all black and soot covered on the bottom that is inside the cylinder. Good firing spark plugs will have a tan or brown appearance down at the bottom, with very little deposits on them. (and if black and oily looking and wet, you have likely worn piston rings letting oil burn in there.) So if you could find the miss, it will help you a lot. Maybe you need a tune-up, after looking at your plugs-are they worn down real bad?
Lots of causes for a miss: ignition (plugs, wires, rotor, distributor cap, coil even), gas related (if multiport injection, possibly an injector problem) , and also an internal mechanical problem affecting that cylinder (like a bad sealing valve, a head gasket leak: do a compression test to check for that).
I hope I have helped you in some small way. Good luck.
Feb 02, 2014 | Toyota Cars & Trucks
Do you have replace spark plug tubes when replacing gromets and valve cover gasket on nissan alti mma 05 there was oil in the spark plugs........
IF the tubes are not deformed it should not be necessary. Most problems come from not replacing the grommets and seals every time the plugs are removed.
Aug 25, 2013 | Cars & Trucks
How to change spark plug gaskets on a 1999 ford escort sport
The spark plugs do no thave gaskets they are a tapered fit into the cylinder head. Do you mean the seals (2.0 DOHC) that keep oil out of the plug wells, if so you must remplace the valve cover gasket, a very simple job on this engine.
Sep 05, 2012 | Cars & Trucks
Need to replace valve cover gasket on 01 pt cruiser
This procedure takes approx 3 hours.You have to remove upper intake manifold and cylinder head cover,in order to replace valve cover gasket.
Its a huge procedure,but can be done easily.
Click the link below and follow step by step details.
http://technoanswers.blogspot.in/2012/06/valve-cover-gasket-removal-guide.html
This will help.
Thanks.
Jun 27, 2012 | 2001 Chrysler PT Cruiser
Oil on the spark plugs/failing cylinder?
The important question is - oil on the top half of the spark plug, or oil on the bottom (fire) end of the spark plug?
Oil on the top end of the plug means that your valve cover gasket is leaking. This is a common problem. BMW valve cover gaskets get hard and shrink and have to be replaced about every 10 years. It is an easy do-it-yourself repair, but it can take a while to dig the old hardened gasket out of the valve cover without scratching it. Just be patient.
If the bottom (fire) end of the plug is wet, either the plug is not firing due to a failed coil or some other electrical problem, or you have bigger problems in that cylinder. A compression test is in order.
Sep 13, 2011 | BMW 325 Cars & Trucks
My light says ignition coil b. also the primary and secondary.......what is the primary/sec / AT FIRST IT SAYED #6 misfire. also it still has a slight miss at idle and crussin in overdrive . Can you please...
It sounds like you need a coil for # 6 cylinder .LS's have a issue with the valve cover seals leaking oil into the spark plug holes and causing a misfire if this is the case you have to replace all the gaskets for the valve covers clean out the oil and might as well do sparkplugs then too. Its more of a dealer repair then. If no oil in that cylinder try replacing coil and spark plug.
Mar 31, 2011 | 2004 Lincoln LS
Cause of oil in sparkplug tube?
1.your valve cover's spark plug chamber seal is leaking. Which requires removing the valve covers and replacing the gaskets and seals. 2. Excessive oil spills on to the valve cover and ignition coils when adding oil.
**This excess oil on the plug boots can cause the coils to short and eventually fail.
Apr 20, 2010 | 2001 Lincoln LS
There is engine oil in the spark plugs 3 of them,
If the oil is not in the cylinder,and is just around the spark plug,then get a new valve cover gasket with grommets,and spark plug seals,and replace it,if it has oil in the cylinders,it should be smoking,when running,and using oil.
Apr 19, 2010 | 1996 Honda Odyssey
Where is the pcv valve located on a 2003 ford ranger
  • The PCV valve can be located in several places. The most common location is in a rubber grommet in the valve cover. It can be installed in the middle of the hose connections, as well as installed directly in the intake manifold.
  • Once the PCV valve is located, make sure all the PCV system hoses are properly connected and that they have no breaks or cracks.
  • Remove the air cleaner and inspect the air and crankcase filters. Crankcase blowby can clog these with oil. Clean or replace such filters.
  • Oil in the air cleaner assembly indicates that the PCV valve or hoses are plugged.
  • Make sure you check these and replace the valve and clean the hoses and air cleaner assembly.
  • When the PCV valve and hose are in satisfactory condition and there is oil in the air cleaner assembly, perform a cylinder compression test to check for worn cylinders and piston rings.
  • Feb 27, 2009 | 2003 Ford Ranger Regular Cab
    98-01 Nissan Altima GXE SE Hood Panel Assy Steel NI1230151 F51009E030 Logo
    44 people viewed this question
    Top CARPARTSDEPOT Vehicle Parts & Accessories Experts
    Danny
    SriPhi
    Timllfixit
    Are you a CARPARTSDEPOT Vehicle Part and Accessory Expert? Answer questions, earn points and help others
