Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Mitsubishi ws-55859 reset light flashing won't reset
    Problem Solver:
  • 6 Answers
You have blown capacators in your DM board. Here is a video that I used that guides you step by step video instructions for repairing TV. Bought the capacators at Radio shack for appx. $2/each.
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Posted on Sep 20, 2009
I have a mitsubishi tv model # WS55859
and the green on light just blinks and it will not come on
Posted on Oct 17, 2009
3 Suggested Answers
  • 5528 Answers
SOURCE: MITSUBISHI DIGITAL TV WS-55859 GREEN LIGHT
This could mean the DM (HD tuner) failed. In the future connect your TV to a good surge protector. The manufacturer's solution is to replace the module and swap the memory from the failed part to the new one. (Except for the memory it is just an unplug one and plug in the new one.)
If you are handy with a soldering iron, you may be able to fix this by opening the DM module and removing 8 capacitors (as I understand the board) and replacing them. All 8 are 1000uf 16v 105C Capacitors
This URL has an good explanation of the process: http://www.hometheaterspot.com/fusionbb/showtopic.php?tid/137881/
I hope this helps.
Posted on Jun 19, 2010
SD Tech
  • 14553 Answers
SOURCE: My Mitsubishi Model ws-55859 Wont turn on. The
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 23, 2010
Timer light flashes tv won`t turn on. mitsubishi model #55859
You have a bad DM board - the capacitors are bad and need to be replaced. I was able to replace them myself. There are no replacement parts available and many repairmen will charge hundreds of dollars and there is no guarantee they will fix it.
Jul 06, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Blinking timmer light mitsubishi 1080
Video instructions for repairing Mitsubishi WS-55859 HDTV:
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Jan 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi 55859 Blinking Green Light
Dec 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55859 parts
time to get a new one.
even you get the main board, you might have other problem that has not show up yet.
Oct 05, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Sep 11, 2008 | Mitsubishi WS-55859 55" Rear Projection...
WS-55859 Won't Turn On
this is a job for experienced tech most of the problems are rela ted to convergence IC's in this case
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Ws 55859
call a repair man, 4 caps on DM bd are bad i have repaired this problem before
Oct 22, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
771 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
