A465 lennox diagnostic codes - Heating & Cooling
Could you please give me the code for a Lennox HG31ES air conditioner? I have just bought a universal remote and haven't got the code. Regards Lynda
I doubt a 'universal remote control' will work for air conditioning. They are for televisions and DVD players.
If it is one of these, it should work out of the box.
Over 2000 CODES, OPERATES ALL LENNOX MODELS.
Full function universal remote control for all brands of air conditioners.
Large electric blue LCD backlight display. A product to satisfy all exigencies, with an attractive design and a full range of original brands covered.
Extremely easy to program with auto-search feature.
With over 2000 codes in the memory it makes this product the most complete on the market.
The big display with Backlight and clarity of indication of the functions complete the huge success of this product.
User manual included.
Supplied with wall mount bracket.
Remote control is gold in colour.
*Requires 2X AAA Batteries.
REPLACEMENT UNIVERSAL LENNOX AC AIR CONDITIONER REMOTE CONTROL FULL...
Or you could ask Lennox direct?
http://www.lennox.com/help
Dec 06, 2016 | Heating & Cooling
Lennox model 80MGF3-75A-2 Furnace will not come on. Where do I start
http://www.ehow.com/info_12194827_led-codes-lennox-80mgf-furnace.html
May 15, 2014 | Heating & Cooling
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Lennox codes
I have a gas Lennox elite furnace & code light is not turning on
Jan 13, 2014 | Heating & Cooling
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
h1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Jan 16, 2013 | Lennox Heating & Cooling
Replace thermostat
What is the model number of the old tstat and furnace?
Aug 07, 2017 | Heating & Cooling
I need a list of codes for my lennox hp26-036-7p the red and green lights on the outside unit are flashing continuously. the outside unit acts like it wants to come on and i can her it running but it is...
LED Flash list should be located on the inside of the unit's electrical panel by the wiring schematic, and by counting the flashes in between the longer pauses should give you the diagnostic code. A continuous steady flash can also mean normal operation, and something else on the inside could be holding you out like a float switch tripped (located on emergency pan underneath Air Handler Unit If Applicable) etc.
Jul 05, 2011 | Heating & Cooling
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
IHAVE A465 and the bake feature does not work all of the time.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 17, 2009 | Whirlpool GS460 Gas Kitchen Range
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
