Question about Razor E100 Electric Scooter
Battery razor e 100 replace - Razor E100 Electric Scooter
    Habit-Forming:
    Scholar:
  • 89 Answers
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Posted on Feb 13, 2015
2 Suggested Answers
  • 850 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
I need to replace the battery in a Remington women's razor model wdf 1600
  • Open battery compartment
  • Note correct polarity and remove
  • Install new battery
  • Close battery compartment
  • Test operation
If the razor does not work, the replacement battery may be defective
Jul 12, 2016 | Remington Health & Beauty
Tip
How To Change Replace Battery on a Electric Razor Scooter E200
<utube src="iR-CZ_uOvOo"></utube>This Video will show you how to replace or change the battery on your Razor E200 electric scooter.
on Aug 04, 2013 | Razor E300 Scooter
I ride my scooter and then it turns off..the button pops out and when I push it back in it will work for a few moments then stop again.. is the battery done?
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
Jan 11, 2011 | Razor E300s Electric Scooter With Seat
Norelco 8894XL is charging to over 100 minutes. According to manual, it supposed to charge only to 100 minuyes. What is causing it overcharge?
I have owned a Norelco 8894xl for over 10 years. My battery meter will show 127 minutes after the razor is fully charged. The battery is not over charged. This is normal and does not indicate a problem. Hope this helps.
Jan 07, 2011 | Norelco 8894 XL Electric Shaver
Wont charge tryed a new charger think its the battery can i replace the battery ?
Razor E100 batteries are easily replaced & there are guides on how to this on razor.com, genuine Razor batteries are available at most good Razor product stockists.
Dec 30, 2010 | Razor E100 Electric Scooters Red
We have A 300 razor battery scooter but do not have the battery pack or the charger.
Buy a replacement battery pack and charger at razor.com or http://electricscooterparts.com/razore300.html
Jul 10, 2010 | Razor E200/300 Electric Scooter Battery
Razor charged but not running
You didn't specify how old you model is.
Generally I would say, the battery is failed.
You might try taking it to whereever you bought it and politely ask for a replacement. Its also a good idea not to leave these in cars during sub freezing weather.
Apr 09, 2010 | Norelco Cool Skin 7775X Electric Shaver
E-100 razor scooter battery will not take charge
Jul 17, 2009 | Razor E100 Electric Scooter
WHICH VOLTAGE HAS THE 2 BATERY PHILISHAVE TYPE HQ 6740/A
Input voltage : 100-240 V, 50/60 Hz
Power consumption : max. 9 W
Motor voltage : 2.4 V
Battery : 2x NiMH AA
Battery capacity : approx. 1100 mAh
Charging indicator : 1x duoLED green / red
: charge / battery low
Charging time : approx. 8 hours
Charging current : 200/25 mA time dependent
May 21, 2009 | Philips Philishave Cool Skin HQ6740...
Razor E100 Electric Scooter Logo
143 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
