Question about HP Compaq WF1907 Monitor
Junky speakers Well, with my WF1907 speakers, it's stereo for one second, then one speaker breaks out and my monitor's audio becomes mono. What's the problem?
  • HP Master
  • 2,404 Answers
One of the speakers is blown so unless you can find a replacement speaker for the blown one then you have to either buy a set of other speakers to replace the speakers in the monitor or buy speakers you can hook up to output of the computer.
Posted on Jun 29, 2009
Stereo only playbacks in mono. it used to play stereo
Stereo is actually two identical amplifiers which when the left and right of a stereo signal is fed into the respective inputs will reproduce the stereo sound through the left and right speakers.
Mostly there is a mono/stereo switch so if only a mono signal is available it is reproduced through both speakers.
You don't make it clear whether the playback is in mono or half a stereo?
If playback is in mono it will emerge from both speakers but the directional element will be absent. If the playback is in half a stereo the sound will emerge from one speaker only or mostly one speaker.
Most common problem is the failure of one of the amplifiers which could be electronic or the failure of any of the various switching usually used in such things.
The amplifiers can be tested by injecting a signal into each amplifier input and will be found satisfactory if the sound emerges from each speaker in turn at a similar volume.
Sep 01, 2017 | Audio Players & Recorders
Is my zte n817 phone only play in mono? Can it be changed to stereo?
No it can't. Only iPhone 7 is stereo. The normal phone earphone becomes a speaker along with the speakers at the bottom.
It will however play stereo through a speaker system.
Feb 14, 2017 | ZTE Cell Phones
Mono stereo function
Tv Speaker; Stereo/dual Reception; Nicam Reception ...
www.manualslib.com > ... > Flat Panel TV > 141K TX > Owner's manual
LG 141K TX) Manual Online: Tv Speaker, Stereo/dual Reception, Nicam ... Stereo. Dual. Mono Sound Selection. In stereo reception if the stereo signal is weak, ...
Video Mode; Audio Mode; Still; Stereo/mono - ManualsLib
www.manualslib.com > ... > LCD-32CA9S > Owner's manual
Dec 21, 2015 | Televison & Video
Where do I get a volume control switch for a M-Audio studiopro 3?
@ Radioshack PN 271-0002 Volume Control with Push Switch, it will fix the speakers but make them MONO, so you need 2 of them to make it stereo. I recommend 2 cause this speakers have the volume distribution problem from factory.
Jan 02, 2011 | M-Audio Studio Pro 3 Professional Desktop...
The speakers no longer work. They were working 2
selectbanker, As a test only try this. Remove green plug from rear of pc. Find old am/fm stereo transistor radio or even a portable cd player and connect the green plug to your "new" audio source. Can you hear anything coming out of the monitor's speakers? Also try a set of stereo headphones in the green audio "out" jack to see if sound is coming out of the pc. Narrow down where loss of signal occurs first. 12fixlouie
Apr 07, 2010 | HP Compaq WF1907 Monitor
I have a HP tower and compaq monitor, does this affect the speakers on the monitor? Since I changed the towers out the sound hasn't worked
HP and Compaq are actually now one company. So depending on the age of your tower and the age of the monitor they should be compatible.
First you should check the small speaker icon located in the task bar in the lower right hand corner of your screen. Is there a red circle with a line through it?
First check your connections to the speakers. There are a couple ways to get the audio signal to the speakers so make sure you have a connection that can carry the signal. The primary one is through the Green Audio Out jack on the back of the tower to the Green Audio In jack on the monitor. HDMI cable can also carry a audio signal.
Still no signal?
If not left click the icon and make sure the Mute Box is not checked.
Signal?
If not then right click on the icon. You will be given two choices from a small pop-up dialog box (Win XP and Vista OS), click on Adjust Audio Properties. Click the Advanced Button in the lower right side of the window that opens. Again a small window will open with Speaker Setup choices at the bottom. Go through the list and pick Monitor Mounted Speakers or if Stereo Monitor Stereo Speakers.
If there is a red mark through the icon follow all the steps above.
Remember to reboot your computer after every change.
Additional you may need to go to HP to update your monitor and sound drivers.
In the Adjust Audio Properties, at the top click on the Hardware tab. Now click the Properties button at the bottom. A window will open that should say "This Device Is Working Properly". If not then it's a driver issue. Click on the Driver tab of the same window and click Update Driver button. Sometimes this will work great sometimes not so great and you will need to manually install the drivers.
Let me now if you need any thing clarified or if you are still having trouble after trying the above.
Hope this helps.
Oct 21, 2009 | HP Compaq WF1907 Monitor
My monitor is making a humming noise from the speakers , because i use other speakers (not the ones on the monitor) this is a problem what could cause this
It is probably a problem with the audio jack, try using other speakers or connect another audio source to your monitor. If the problem persists, you better contact your vendor for a faulty product
Jun 19, 2009 | HP Compaq WF1907 Monitor
Sound from Hannspree hf199h
you need to plug it into the lime green(if theres one) three outlet audio jacks serve different purposes when their set for mono or stereo
Dec 20, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
Speaker cables
standard 1/8" stereo audio input cable
http://www.radioshack.com/sm-6-ft-shielded-cable-1-8-stereo-plug-to-1--pi-2102949.html
Sep 09, 2008 | HP Compaq WF1907 Monitor
Terratec phase 22 problems with getting stereo sound
You must make stereo cable (adapter), from 2 mono outputs to 1 stereo.
Jun 16, 2008 | TerraTec Electronic PHASE 22 Sound Card
HP Compaq WF1907 Monitor Logo
128 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
