Question about HP Photosmart C5180 All-In-One InkJet Printer
HP C5180 error messsage Oxc19a0024 will not print. what to do.
  • 4,041 Answers
Ok this is a old postint but you may come back to see it or it may be handy for some one elles.
Solution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
  17. All the best: Pineworks
Posted on Jan 30, 2010
Photosmart C5280 error messsage
1 - disc encoded may be dirty, clean it.
2 - disc encoded sensor can also be dirty, clean it well.
3 - Check the connection of this sensor with the logic board.
4 - Check if the paper sensor is not obstructed or dirty, it can be with a small piece of paper.
Good luck
I wait feedback!
Apr 17, 2012 | HP Photosmart C5180 All-In-One InkJet...
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Oct 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
Solution 2:
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
On HP Photosmart C5180 Error Message 0xc18a0201
call hp total care 1800 4746836
u knw i cn tell u the steps but if u do even 1 of the steps wrong ,ur printer wont work anymre so contact them
...hp technicians will be able to take care of u
thanhks
Aug 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error: 0xc18a0107 Printer HP C5180 All in One
I had the same problem for a few days.
Each time, I switched on my HP C5180 printer, the Oxc18a0107 message was displayed.
I tried the solution that I found on the net (power off, power on while holding on OK and HELP keys) unsuccessfully ...
Then I bought new ink cartridges and I put them after resetting the printer.
No more error message ... It works well now.
Abbesses
Apr 09, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error oxc19a0024
Well i would recommend you to uninstall & reinstall the printer software... just make sure that the printer is not connected to the system when you are reinstalling the software.... Connect the cable only when the printer software installation wizard suggestes to connect the printer to the system...
Jan 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer error messsage
attempt to clear the print spool and set the its settings to print directly to the printer. Do a test print, then enable print spooling again. If the same thing happens, uninstall and reinstall the latest printer driver
Jan 16, 2009 | HP LaserJet 4350 Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
1,608 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
