Question about Venturer Televison & Video
Tvdisplaysnosignal how to identify the connections on a 22in. venture flat screen without removing from the wall
I have a bush 22in combi and the screen keeps going blue before knocking off completely...
what's a "combi"? And the blue screen just before it shuts off sounds like something to do with the plasma tube
Oct 30, 2013 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
I need a remote for a 22" Venturer Flat Screen TV/DVD Model PLV7122
You can always try a Logitech Harmony remote. The model 300 is pretty inexpensive. You program it by using your computer and connect the Harmony with a USB cable to update it.
May 05, 2011 | Venturer Televison & Video
I own a Sylvania 22in LCD tv and when i plug my vga cable in to it from my toshiba laptop the tv screen says format not supported. What do I do?
You have to change the second screen resolution for you to be able to use second screen. Sometime 800X600 or 1048X760 will work.
Mar 19, 2011 | Sylvania LC195SLX LCD TV
How do you take the base stand off of an envision 22in lcd tv? I want to mount it to the wall?
There is a screw on the part of the base where it connects to the monitor back, it is located on the pivoting arm, remove or take loose this screw and lift the base by holding the side opposite the screw. the base should lift off with at very most just a bit of wiggling. You can now use the wall mounting screw holes located under the corners of the sticker on the rear of the monitor, they are usually covered with a perforated area.
Jan 16, 2011 | Envision H22W 22" Monitor
I have a Hitachi CME LCD 201 Flat screen TV and
Just the exact model and serial numbers. Or you could search for a "universal" remote that supports it.
Jul 10, 2010 | Hitachi Televison & Video
I have just got 22in plasma screen in bedroom but signals only 74% I have bought tv/fm 2 way signal booster will that help?
74% is good. If this is from an outdoor antenna and you are the only one connected to it no the booster will not help. The signal would need to be boosted at the antenna itself. Please take a few moments to rate my answer. Thanks..
Nov 19, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
I have a 42 inch flatscreen Venture television and I need to mount it on the wall. How do you remove the base stand
CHECK YOUR INSTRUCTIONS OR GO ONLINE FOR THE GUIDE. SOME MODELS JUST FOLD FLAT AS TO NOT INTERFEAR.
Oct 10, 2009 | Televison & Video
Screen is black on fullscreen
i have a 22in dell monitor with the same problem anyone have an answear?
Jul 07, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Venturer 19" lcd tv
i have the same problem, i don't no what to do. Its so annoying. It randomly worked once and then the same thing happened again.
Nov 22, 2007 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
