Question about Brookstone SmartSet Alarm Clock
How do I turn the alarm off on model CKD5810D
How to turn on the alarm on a Garfield Alarm clock model 887-99.
I believe to turn the alarm on or off, you have to push the nose in.
Feb 21, 2017 | The Computers & Internet
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Why does kidde smoke alarm red button(tedt weekly) keep blinking
    Most smoke alarms have some indicators that mean different things, depending on the model number. To find the model number, turn the unit counterclockwise about 1/8 of a turn and pull down from the base. Kidde's website has user manuals for their products. Go to Kidde Product Documents firex smoke alarm manual to find the manual for your model.
    Oct 02, 2014 | Home
    I lost the manual for my Teac Radio/CD player. The alarm is set for midnight and I do not know how to switch it off!
    If your Teac Radio/CD Player is the model: GR 7I then you would be able to turn the alarm off by doing the following.
    Press the Alarm 1 or Alarm 2 button(s) to toggle each alarm on and then off.
    If you have a different model Teac, please let me know which model so I can further assist you.
    Aug 07, 2011 | Teac Audio Players & Recorders
    I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
    Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
    For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
    Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
    Cant turn off alarm on RCA alarm clock model 3715A
    Closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
    It is almost exactly the same model as the #3700 series.
    If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
    Nov 05, 2009 | RCA Radio Alarm Clock
    Need to turn off alarm
    A model would be most helpful here. Timex has a couple different alarm set ups.
    With most of their watch if you cycle through the modes using the mode button you will come to alarm. Depress set and the alarm will toggle on or off.
    With Dial alarm models you simply depress the alarm button (the one with the red stripe).
    Sep 18, 2009 | Timex Watches
    How to turn on the alarm and turn it off
    To enable the alarm, push and hold either alarm 1 or alarm 2 button on left side of face... eventually it will switch the display and say alarm enabled and you can then push the alarm button to switch between buzzer / radio / off.
    Nov 18, 2008 | GE 2.4GHz Cordless Bedroom Phone
    Top Brookstone Audio Players & Recorders Experts
    Henry  Thomas
    Henry Thomas
    Carlos L. Burgos
    Carlos L. Burgos
    Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
