Question about Miele Coffee System
Stuck in Heating Phase
The system is set in heating phase. I ran the descaling program thinking that was the problem. but its still stuck in heating phase.
5 Suggested Answers
  • 3 Answers
SOURCE: descaling
I had this happen once and had to put it through the descale process again. Just put more water in the tank, try it again and see what happens.
Winesnob
Posted on Nov 17, 2007
mirran
  • 515 Answers
SOURCE: Descaling, won't read Program MOde
I can not this type of machine, i work with Saeco, La Pavoni and Kenwood.
I can see if i can search after a solution to you but i can not promise that i can find any:-(
Best regards
/Mirran
Posted on Jan 29, 2009
  • 10 Answers
SOURCE: descaling
There is a software Problem on the electronic in the back of the coffee maschine.
Changing that electronic to the new version will sort that Problem.
Mr. Cool
Posted on Feb 01, 2009
  • 5 Answers
SOURCE: Descaling, not reading program mode
turn to lock and hold ^ button for 10 sec to change security setting on or off. should be off . then switch to program mode and use up & down arrows to descale with * , hit enter turn on steam.
Posted on Aug 15, 2009
I have a CPU with burnt fuse and board looks smoke damaged wondering whether to replace fuse or entire CPU?
fuse costs about fifty cents , board costs over two hundred , but I would say smoke damage is leaning more like the board me ! Id have a small appliance tech look at it , if there is other parts ruined I missed id rather pay him his diag fee than waste money on a two hundred board that's not going to fix it ! It would go towards a new one
Sep 29, 2016 | Nuova Simonelli Premier Maxi Espresso...
My Miele CM 5100 is stuck in the Heating up Phase. How do I fix this?
The 'on' light may not indicate if the machine is actually heating.
I suspect the heater coil itself has failed or a thermal fuse (safety fuse) has failed and these are normally welded on the heater coil itself.
A multimeter would quickly find the failure and they are now cheap enough that everyone should have one at home.
You needn't spend >$20 US to buy one, more money wilol not give you more utility.
They can be had at auto parts and electronics stores.
Oct 06, 2014 | Miele Coffee Makers & Espresso Machines
Why is my dishwasher stuck in cycle ?
In which phase is stuck your dishwasher ?
Is it pre-wash phase, washing phase, rinse or drying phase ?
Dado
Sep 04, 2014 | Zanussi Dishwashers
How to fix P2430 code on a 2006 Pontiac Grand Prix
P2430 Secondary Air Injection System Air Flow/Pressure Sensor Circuit,
The AIR diagnostic uses 3 phases to test the AIR system:
DTCs P0411 and P2430 run during Phase 1
DTCs P2430 and P2440 run during Phase 2
DTC P2444 runs during Phase 3
During phase 2, only the AIR pump is activated. The solenoid valve is closed, this is p2430 and p2440. -The AIR system pressure sensor is stuck. good-day !!
Jul 15, 2011 | 2006 Pontiac Grand Prix
I am working with a Dayton 2YU39. The name plates states that it has to be powered by 208 volt system. There's a 3-phase panel and a single-phase panel. The 3-pahse panel L1 to ground is 118 volts. L2 is a...
Here's what I think but you will have to check it out...
The fan motor in the 39 heater is a 120V fan there fore it cannot be hooked to the 240 which potentially could have the high (wild) leg as one of the fan legs...
The 240V 36 unit probably has a 240v fan motor....
Now if you were to make sure that the leg that fed the motor was a 120V to ground leg then you will be okay...
Hope you understand where I was going with this...
heatman101
Oct 27, 2010 | Dayton 2YU44 Electric Heater
My heat pump package unit compressor draws high amps and keeps going up until it blows the 40 amp fuse on heat only. and on cooling only works for a minute or two and shuts off and starts again but draws...
This could be many things, but check the following:
1. The reversing valve - make sure it works and is in the correct position for the selected operation (heating or cooling)
2. Turn off the power to the system. Megger the compressor - this takes special instrumentation, but if you don't have it, set an ohm meter to Ohms x 10,000 and check each lead to ground as well as phase to phase. Look for shorts or open windings. You will need to disconnect the compressor wiring
3. If the unit has auxiliary heat, make sure the elements or the controls for them aren't stuck on - this could be a control board problem.
4. Check the outdoor unit defrost cycle for stuck heating elements or a faulty control board/stat.
5. I'm not sure if this unit has hot gas defrost, but if it does, that should also be checked.
6. Check the compressor contactor and make sure the contacts are transferring the power to the compressor. Amp check each leg to determine this.
Dec 22, 2009 | Goodman CLJ30AR32 Air Conditioner
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
I have a 310v 3 phase coffe machine how can i use
Hello tonyludlow1,
I can speak from personal experience with 3 phase. I built a 220v 3phase converter to run my 3 phase commercial table saw. I do not believe you will have success running a 310v 3 phase coffee unit. It is likely that the heating elements are set for 310v, and if you run it on 220v domestic wiring your heating elements would not heat optimally. If it could be done, you would need to rewire the electrics in the coffee unit to 220v. Sorry to be a downer. Positive feedback appreciated. Kind regards, NormanZ :o)
Jul 08, 2009 | Coffee Makers & Espresso Machines
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Miele Coffee System Logo
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
