Question about HP Computers & Internet
N345 pd 1w - HP Computers & Internet
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
Tming settings on gears how to put them together by the marks
First, make sure you've got the oil pump drive gear and the pinion on the pinion shaft of the crank and the nut properly torqued. Identify the cams. You should have a "1W", "2W", "3W" and a "4W". "1W" is the rear exhaust and "2W" is the rear intake. "3W" is front intake and "4W" is front exhaust. They go into the engine cases in order 1W in rear, next 2W over the pinion gear, 3W in front of the pinion gear, and 4W all the way to the front of the engine.
Install the "1W" cam. Then install the "3W" and the "4W" cam with the timing marks aligned. Now position the pinion gear with the timing mark straight up and lock the crank. Now, you must install the "2W" cam last making sure that the three timing marks are aligned with the pinion gear, the "1W" cam, and the "3W" cam.
If you can't figure it out, contact me directly at wd4ity@bellsouth.net and I'll send you a picture.
Good Luck
Steve
Sep 06, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
I have a Hitachi 53FDX20B and the picture is looks stramge
It is not your Picture tubes that are bad, it is your Convergence IC's. The IC # to use is STK392-180. These are better than the originals, also invest in these resistors: 1.5 ohm 1w,,,1.8 ohm 1w,,,2.2 ohm 1w. (watt). I would by 4 each. Your soldering skills will come into play so roll up your sleeves and go to work.....Good luck ! and let me know how you do.
Aug 26, 2009 | Hitachi Televison & Video
Assembly for Dorel Asia da0504kmc-1w day bed
email them Das@dorel.com include model number and say you lost instructions they will email them to you
Jun 01, 2009 | Dorel Alexander
What is the replacement of the RM25 diode?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Industry Number : RM257
NTE Device Number: NTE148A
ZD-55.0V 1W,DO-41
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Industry Number : RM25V
NTE Device Number: NTE5089A
ZD-51.0V,1W,DO-41
I hope it helps!!!
Dec 02, 2008 | Panasonic Televison & Video
Need owner's manual for Bose Wave Radio Model AWR1-1W
i can email a copy of the manual for you, for $5.
Nov 18, 2008 | Bose Wave Radio
Breville 800E5Xl didoe
DIODE ZENER 24V 1W 5% DO41 1N4749AOrder 'diode zener 24v 1w 5% do-41 - 1N4749A' online from Digi-Key. Manufactured by Fairchild Semiconductor. Digi-Key part number 1N4749A-ND.
parts.digikey.com/1/parts/420514-diode-zener-24v-1w-5-do-41-1n4749a.html - 22k -
Jul 14, 2008 | Breville Die Cast 800ESXL Espresso Machine
My tv has a green shadow behind everything on it
Tim,
Gee I'm pretty good with electronics and I've never heard that joke!
What you have there is a convergence problem. Your unit takes two STK392-110 Ic's at position numbers IK04 and IK05 respectively. Also check and replace as necessary Rk50 (2.7ohm /1w), Rk62 (2.2ohm /1w), Rk63 (150ohm /2w), Rk46 (1.8ohm /1w), Rk42 (3.3ohm /1w) And Rk43 (220 ohm 2w). In fact test all of the 2.2ohm resistors in the yoke return just out in front of the amps for change in value.
Also make sure to use Sanyo original Ics and not some asian knock-offs which are readily out there.. Get them from Acme in Florida http://www.acme-sales.net/index.shtml and rest assured you're getting Sanyo originals..
Bill
Feb 09, 2008 | Hitachi 43F300 43" Rear Projection...
Computers & Internet Logo
11 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
