Question about Health & Beauty
A images of ears
Ear.drum
    New Friend:
    Problem Solver:
  • 10 Answers
You can use any search engine, type in internal ear canal and just click on images.
Posted on Apr 14, 2014
2 Suggested Answers
  • 46 Answers
SOURCE: Even if I have ear ache only in one ear, should I use the ear candle on both ears?
Yes - do the treatment on both ears so it's balanced out.
Posted on Feb 20, 2013
What percentage volume of peroxide can I use for earwax
do not use peroxide in the ears unless you want to burn your ear drums out
there are plenty of ear wax removers that softens the wax and lets it run out
Feb 19, 2018 | peroxide Health & Beauty
Tip
Taking Care of your Kid's Ears
Ears aren't very high maintenence but there some things you should know about ear care that will help ensure healthy, happy ears.
What's the story with earwax?
Do you need to clean it out or should you leave it alone? Alot of kids don't realize that earwax is really helpful as it is there to protect the ear.
In general ear wax doesn't need removing as it makes it's own way to the entrance of the ear and comes out by itself.
although ear buds are really popular, they are actually damaging to the ear as it pushes the wax deeper in and can damdage the ear drum.
So don't stick anything small in your kids' ears to clean out the wax. Let it just do it's own thing and come out when it's ready.
Is swimming a problem for ears?
Water and ears are generally ok but there is a condition called swimmer's ear. It's basically an infection in the outer ear that is caused by swimming water getting stuck in the ear canal.
Usually ear drops will help sort it out quickly. If you have a problem with persistant ear infections you can buy special ear plugs that help keep the water out while you're swimming.
Pierced Ears - Is there anything special that I need to do for them?
When you get your ears pierced you need to follow the instructions from the salon and not remove the earings for up to 6 weeks, otherwise the hole might close up.
Pierced ears can easily get infected, so use an alchohol rub if you start to see any redness or sores.
If it gets very badly infected you may need an anti biotic cream but don't panic, it's very common and should clear up quickly.
Be Well.
on Feb 03, 2014 | Health & Beauty
My husband has a perforated ear drum he has a throbbing sound is this normal for this condition many thanks
hi Lyn.
this is all i could find out.
We call it a tympanic membrane perforation and there are many different causes. The most common cause is an ear infection that ruptures the eardrum. And such perforations always heal spontaneously. ... A ruptured eardrum will usually cause some degree of hearing loss.
you could try this link and see if it helps you out some more on this matter.
perforated ear drum throbbing sound Google Search
Dec 14, 2017 | Washing Machines
Replacing minijack
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
Apr 11, 2014 | Klipsch Image S4a black For Android In-Ear...
Can you do serious damage to your ear by sticking something in it?
The simple answer is Yes!! One of the most common problems with ears is perforated ear drums caused by objects being put into the ear and this can range from foreign objects being inserted by accident, to over enthusiastic ear cleaning with a cotton bud. There is a bit of a wives tales that says you shouldn't put anything bigger than your elbow into your ear. This might be a bit of an exaggeration but it's actually very important to keep things out of your ear.
Feb 20, 2013 | Health & Beauty
The printings in my hp laserjet 1010 keep appearing with a white band at the right side of the page, i've tried to reinstall the toner but still appears...can you help me guys? please!
Go to paint shoot black colord print page, while printing half page switch off the printer remove cartrige gently, check on catridge drum surface is there any while patch in black image on drum ? if yes *** open laser scanner assembly clean the reflect mirror with ear buds gently fix it back then try once..****check image on paper is there any white band? id no replace teflon sleeve/fuser.*****If white patch is not in image clean/replace the transfer roller. best of luck..
Sep 12, 2011 | HP LaserJet 1012 Printer
How do I clean the charge wire on Konica Minolta 1350 laser printer
Hi
You can find this wire on the front side of the drum assy. You can check near the drum it is known as Corona wire which passes high voltage to erase the drum making it ready to receive the next image. You can clean if with a ear swab without any cleaning liquids. And also do remember that sometimes there is an Blue color tab on right or left side of the toner which moves hence you can clean with it as well. Its been given for the same purpose.
Jul 24, 2011 | Konica Minolta PagePro 1350W Laser Printer
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Health & Beauty Logo
123 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
