How to enter the cmos bios of manli nvdia mcp61
How to enter the cmos bios set-up of manli nvdia mcp61?
4 Suggested Answers
SOURCE: Can't enter BIOS setup with F2
One thing that I could suggesg is get a new very nice mother board for about $59.00. You don't want to send a payload to the moon?, do you ?. Well get yourself a nice 2nd hand mother board.
Posted on May 09, 2008
bravsman
  • 94 Answers
SOURCE: CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Posted on Nov 24, 2008
  • 256 Answers
SOURCE: cmos settings error system hait,
You will need access to another computer and go to: http://www.asus.com/, choose you country, then "Download", the on the next page, "Download" again. Select you "Product, Series and Model". Motherboard, Socket 478, P4P800-SE click "Search". Then choose you operating system. You will get to the page where you can download the latest BIOS, and install program. Read how to upgrade your BIOS and follow the directions carefully.
I suggest you also change the CMOS battery before you upgrade to make sure a dead battery is not the cause for the CMOS corruption.
Posted on Jun 10, 2009
What is BIOS password?
No way to know YOUR bios password.
If you've neverassigned a BIOS password, press enter without inputting anything.
If you have a BIOS passwoed, you can reset BIOS rmoving CMOS battery
laptop cmos battery
Tutorial How to replace the CMOS battery in your laptop
How to Clear Your Computers CMOS to Reset BIOS Settings
How to clear an unknown BIOS or CMOS password
Apr 01, 2015 | Computers & Internet
Skips CMOS setup
The BIOS information is typically found at or near the top of the POST screen for a very short time
ALR PC non / PCI =CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaultsusing the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
this will reset your cmos
Jan 25, 2014 | Medion M3 Composer 5200 PC Desktop
Cmos wrong settings
Oct 17, 2013 | Computers & Internet
I don't have a password for the set up utility screen!
BIOS password to enter set up?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if no luck with this
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
Hope this helps you
Sep 07, 2011 | HP Computers & Internet
Cmos checksum bad
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
don't forget to vote
Feb 11, 2011 | Computers & Internet
How can I restore my desktop to factory settings?
Clear BIOS/CMOS, this can either be done by way of the clear BIOS/CMOS jumper or you can remove the BIOS/CMOS battery for about a minute and then reintall it in it's correct orientation. This will set your computer to factory defaults. Will then need to enter the BIOS/CMOS by hitting the delete key during POST procedure to set the date and time for example.
All the best.
Your timeous rating of this solution is much appreciated. It's the thumbs up on the top right of this solution.
Thanks
Nov 05, 2010 | Computers & Internet
When ever i power up my toshiba satellite laptop,there are two blank screens with a blue box in the centre saying enter password
the bios passowere has been engaged go to bios by pressinfg del or F1 button on startup go to bios setting password you will see enter password press button with passord blank again it will ask for confirm password enter blank password press enter it will delete all the password if you are un able to enter bios and asking for password remove the cover you will see three jumber pins near ur cmos battery pin one and towo are for normal pin 2 and 3 for clear comos in some there are only 2 pin short the pin to clear the cmos some times shorting doest start the computer dont worry put the jumbers back to the normal position and restart the computer while stating you will see cmos reset press F1 to continue or press DEL to enter bios press DEL and enter the correct time as clearing the cmos the time will be set defult if you cant see cmos jumper pin remove the cmos battery and restrt the computer then shut down the computer and place back the cmos battery in its compartment doing this please remove the power to your hard disk or your haRD DISK MAY GET CORROUPTED
Oct 24, 2010 | Computers & Internet
Ibm thinkpad
The 161 CMOS error means the CMOS/BIOS battery is dead/flat and needs to be replaced.
The 163 CMOS error means the Date and Time could not be updated when you change the Date and Time setting. This is caused by the flat CMOS/BIOS battery.
When you replace the battery with a new one, the BIOS will go back to the default settings, go into to BIOS setting (press F2 when you boot up) and change the Date and Time, then save and exit.
Jul 29, 2009 | IBM Computers & Internet
Nov 24, 2008 | Abit AB9 Pro Motherboard
Cmos checksum error after flashing the bios
I had a similar experience after upgrading my RAM. When you reset your CMOS and have default settings maybe you should check if your RAM timings are correct. I could not get mine to load with both sticks in until I fixed the timings from the default settings.
Jan 20, 2008 | MSI K9VGM-V Motherboard
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
