Question about HEWLETT-PACKARD ProBook 4520s Notebook
Touch pad how do i turn on the touch pad if i had accidentally lock it.
Dubble cliek left upper corner of touch pad,,,,, to turn on or off.
Posted on Apr 13, 2014
    Problem Solver:
  • 19 Answers
The easiest way is to connect a mouse and use it to go to the control panel and mouse and touchpad settings. It can be any USB mouse and they are available for less than ten dollars or even free if borrowed from a friend for the time it takes to correct the settings.
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
Touch pad sony viao vpceb3j1e not working
Hey there. Often times this is a problem caused by accidentally turning it off. Look for a button on your keyboard or near the touch pad to turn the touch pad on/off. If you're using windows 7 and possible below, you won't need drivers to get the touch pad to work normally.
Jul 26, 2011 | Computers & Internet
My touch pad is not working. There is an orange light on it.
I am really sorry to hear that your touch pad is not working. You mentioned that you see an orange light on it, where did you see it? is it on the top of your touch pad? if it's just on the top of your touch pad, all you have to do is just press the button right beside the orange light. Because the touch pad is being disable indicating the orange light, when you press the button you will see a blue light indicating that you enable the touch pad.
Thanks.
Jul 24, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
Touch pad not working
Hi
Maybe you accidentally hit lock key of your touch pad. Just press FN key + F7 key (key logo for touch pad).
Or run the SYSTEM RESTORE, Go to START, Choose ACCESSORIES, choose SYSTEM TOOLS, choose SYSTEM RESTORE and then choose PREVIOUS RESTORE DATE that your touch pad is working fine. If not, use the other restore dates if necessary.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 26, 2011 | Computers & Internet
The water stopped coming out of the water dispenser and the ice maker will not make and drop ice. The line from the house to the fridge is not clogged, the lines to the icemaker do not appear clogged.
Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad.
To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad.
To Unlock
Press the LOCK Touch Pad for 3-5 seconds until the Red light above the
Touch Pad goes out.
Other possibilities:
Household water line valve is not open. -open valve
Freezer door is not closed-Close door tight
Ice & water filter cartridge is clogged-replace filter
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
May 26, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
When I switch on, there is a pad lock symbol that gets displayed and I can't turn up the heating elements.
Thank you for using FixYa. The pad lock symbol is a child safety device to prevent accidental operation. Press or touch the area on or around the padlock symbol and the indicator will go out and thus allow you to use the hob
Mar 04, 2011 | Bosch 24 in. PIE675T01E Electric Cooktop
My touch pad wont work
By the power button, there is another button on the left side of the power, if it is amber color you may have accidentally pressed it and locked your mouse and touch pad. Press it once again and try your pad. Let me know if this works!! Ive done the same thing, many times and couldn't figure it out!
Oct 15, 2010 | Acer Aspire 4520-5582 Notebook
Dear Sirs, I have been using Toshiba Satellite M326 for about one year. Suddenly, the touch pad no longer working and now I need to use an external mouse. I am not sure whether it is due to the fault...
If you accidentally turned it off it would be one of the function keys. The one for the touchpad would have a small picture of a touchpad on it and a touchpad with a diagonal line through it. Possibly F9. You have to press and hold the Fn key and press the key with the small picture of a touchpad on it together. If that doesn't work then you might have a problem with the touchpad or the software for it.
Aug 30, 2010 | Computers & Internet
Mouse pad want move
Some computer's include a lock button on the laptop for example on an Hp Pavillion the lock button is in the middle top part of the touch pad. Please tell me what software you are using (Windows 7, Vista, or Xp) and what model of the Acer you are using, or go into your control panel and look under printers and hardware for a touch pad tab and see if you accidentally locked it there. Or a wire has come loose in the laptop and you may need to buy a new Touch pad for your.
Feb 22, 2010 | Acer Computers & Internet
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
HEWLETT-PACKARD ProBook 4520s Notebook Logo
35 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
