Question about Dewalt 3800 PSI Pressure Washer
Can't pull start chord - Dewalt 3800 PSI Pressure Washer
My lawnmower stopped
Check the oil. I bet you seized the engine.
May 18, 2014 | Honda HRC216HXA Commercial Lawnmower
When I pull chord to my troybuilt mower no tension on chord
if you pull the top cover off you will find there is a tin cover in the center that moves the small plate that engauges into the cup shaped part on top of the engine i have seen the screw just back off
Jun 02, 2012 | Garden
The chord you pull to start the engine as snappedand the remaining chord does not retract
you need to remove the recoil cover to replace the cord make sure the hub movers freely
Mar 26, 2012 | Garden
MY PULL CHORD WOULD NOT MOVE. i disassembled the trimmer and eventually was able to free the chord. I was not able to see what had caused the chord to stick and refuse to extend; however it appeared to...
It sounds like it might be seized up. Pull the spark plug out and see if you can pull the cord that way.
Let me know what you find. How old is your machine?
Jim
Aug 07, 2011 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
Broken pullcord . cord is missing how long should new cord be and how hard is it to replace
Just went through this pain today. Here's how I did it. Use allen wrench with T handle to remove the shroud over the carb controls and plug. Then remove about 10 screws and split the case. Use tool that comes with the unit to remove the nut holding the impeller. Behind the impeller, use torx head to get the other bolts to remove the motor. There are two other screws on the other side that hold the motor on. Drop the motor from the case carefully. It is still attached by wires to the throttle and kill switch. Note how the throttle linkage is connected because it will come apart for sure. On the one side of the housing you are looking at the plastic cord spool with the spring unit behind it. My chord simply pulled out of the spool. It was held on with a 10mm nut and start washer (not a good design). If the chord broke, remove the remnant from the take up spool. To rewind the new chord or replace the one that pulled free, you need to wind the spring to put tension on it. Make sure the take up spool engages with the spring tang otherwise it will turn free and not tense the sprint. Once engaged with the tang, the spool should set to the bottom to be level with the metal chord guide. Turn the spool clockwise 3-4 turns until you feel it tighten. With a 2nd pair of hands, hold the tension on the spool and tread in your chord. Route the chord through the take up reel into the hole on the side. Loosen the 10mm nut with the star washer and route the end of the chord through it. Tie a simple knot in the end to prevent it from pulling through. Tighten the 10mm nut which clamps on the chord. Now, slowly, let the spring tension take up the loose chord until fully retracted. Make sure the metal chord guide fits in the slot to channel the chord properly into the take up reel. Hold the spool down and give the chord a gentle test or two. The chord should retract easily and fully. Simple as pie!!! Reverse the disassembly and you are back in business.
Apr 01, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Hood latch inside the rodeo will not release hood. what is the best way to get the hood up?
is it at the handle which pulls the chord?
Can you get to the chord under the dash?
If it is there, then use vise grips to pull it to open it - it may also help having a second set of hands to pull the hood up when pulling the chord...
Otherwise you may be able to get under the vehicle - otherwise I'm not too clear on why it isn't operating..
Feb 13, 2011 | 1995 Isuzu Rodeo
I broke the pull cord on my generator; how do I
you should remove the housing usually 4 bolts
dont remove anything else then look at the pully and remove the old chord tie a knot in the new chord and slot it into the hole on the pulley
you should then see a notch in the edge of the pulley this is for the chord to sit in while you turn the pully enough times to tension the recoil spring once tensioned enough so that it recoils all the chord slot the chord through the hole in the outer casing through the pull hande and knot it job done then refit
May 09, 2010 | Electrical Supplies
Replacing pull string on poulan pro blower
Nov 06, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Scanwagon won't stop pulling back
try installing this patch ;)
hope it helps .
all the best
Sep 22, 2008 | HP PSC 2175 All-In-One InkJet Printer
Dewalt 3800 PSI Pressure Washer Logo
62 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
