Question about Kitchen Ranges
Range change from natural gas to lp gas
Need to change from natural gas to lp gas. what do i need to do
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
Need to change burner nozzle orifices and regulator, go to plumbing store (not home depot) a real plumbing supply store with make and model and they should help you. And just to make sure go to another and see what see they say( compare invoices and knowledge) not an easy job if your new.
Posted on Apr 13, 2014
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Converting broiler in oven from natural gas to lp gas on hotpoint gas range
On the oven portion you will need to turn the oriface clockwise all the way till it bottoms out. This is the conversion from natural gas to lp gas on all gas ovens. Also make sure the valve down toward the back has been flipped off of nat. to lp. Good luck
Mar 02, 2010 | Hotpoint RGB745 Gas Kitchen Range
Convert back to natural gas
the burner orfices will have to be changed ans pressure reg / some have either /or reg / just turn lever to the fuel you are using . but always change the orfices to gas or lp . blk is lp copper nat gas .. you can probably do it with out the instructions it's very simple .. if the other set of orfice's are not in or on range then order them for your model . ..mm
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Natural gas to lp
I have a. caloric mod rls340 with regulator. what is the procedure to switch it to lp from nat gas??
Dec 30, 2008 | Maytag MGR5770 Gas Kitchen Range
Change Natural Gas Model of rinnai Heater to LP model
You can change the dip switches, but you may also need to work on the gas valve
Nov 12, 2008 | Hotpoint RGB528 Gas Kitchen Range
Dacor range natural gas to LP
I have the ERD36 and it runs on LP. Is this purchase a used oven? If not, I would tell the dealer to order it for LP.
Jan 16, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Convert from lp to natural gas
you need to change the gas regulator (if installed on back of oven),pilot and burner orfice your ready to go.happy new year.
Dec 05, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
