Question about TopTeam CarsSeller
Disable passlock system - TopTeam CarsSeller
I installed a new steering column in my 2004 Pontiac sunfire and now it will not start. It tries then I beta back fire.
Anti-theft system isn't allowing it too .
The Passlock™ System is provided in order to prevent vehicle theft if the ignition lock cylinder is forced to rotate or the ignition switch is operated while separated from the ignition lock cylinder case. If starting is attempted without authorization from the Passlock™ System, the powertrain control module (PCM) will disable engine starting. Start disable may be in the form of fuel disable or starter disable, depending on engine application.
The components of the Passlock™ System are as follows:
• The ignition lock cylinder and key
• The ignition lock cylinder case, including the Passlock™ sensor
• The ignition switch
• The body control module (BCM)
• The security indicator on the instrument cluster
• The powertrain control module (PCM)
Feb 05, 2017 | 2004 Pontiac Sunfire
Security light stays on
Annette: According to http://www.realworldautomotive.com/shoptalk-questions-1999-chevy-tahoe-security-light-on-dash-t467.html : " Passlock is a second generation General Motors' theft deterrent system. With the use of a Passlock sensor (mounted in the steering column) the Passlock system can determine improper ignition key and lock cylinder operation by monitoring magnetic fields emitted by the lock cylinder assembly. Once improper operation is confirmed, engine startup is disabled.
The Passlock system eliminated the resistor chip mounted in the ignition key used by the previous Passkey system, including the headaches and expense that went along with it.
Passlock is a subsystem of the vehicle's Powertrain Control Module. The Passlock sensor sends a signal to the Passlock control module. The Passlock module reads this signal and sends the appropriate information to the Powertrain Control Module. If the ignition key and lock cylinder operates normally the engine will start as usual. If it was operated improperly the Powertrain Control Module will be directed to disable fuel injector operation, prevent engine startup, and there will be a diagnostic trouble code set in the Passlock Control Module's memory.
I just wanted to give you an understanding of system operation. It's gonna require the correct scan tool for proper diagnosis. Weak links are the circuits to and from the Passlock Sensor in the steering column. It's a very sensitive signal and can be easily affected by shoddy electrical connections.
If a scan tool displays diagnostic trouble code B2960 (Passlock sensor voltage out of range), the next step would be a resistance check and a complete inspection of connections and wiring involving the sensor. Pay the diagnostic time at a heads-up auto repair shop."
May 13, 2015 | 1998 GMC Sierra
I just installed a new key switch in my 2006 trailblazer it is a napa part now when I start it it will only run for a few seconds and die ?
That is because of the vehicle theft deterrent system ! Do you have a security light lit on the instrument cluster ?
The Passlock?"¢ System is provided in order to prevent vehicle theft if the ignition lock cylinder is forced to rotate or the ignition switch is operated while separated from the ignition lock cylinder case. If starting is attempted without authorization from the Passlock?"¢ System, the powertrain control module (PCM) will disable engine starting. Start disable may be in the form of fuel disable or starter disable, depending on engine application.
The components of the Passlock?"¢ System are as follows:
The ignition lock cylinder case, including the Passlock?"¢ sensor
The ignition switch
Ignition Lock Cylinder Case, Including the Passlock?"¢ Sensor
The ignition lock cylinder fits inside the ignition lock cylinder case and operates the ignition switch when turned by a key with the proper mechanical cut. When the ignition key is used to turn the ignition lock cylinder to crank, start, a magnet on the lock cylinder passes close to the Passlock?"¢ sensor within the ignition lock cylinder case. The magnet activates the security hall effect sensor in the Passlock?"¢ sensor which completes a circuit from the security sensor signal circuit through a resistor to the security sensor low reference circuit. The resistance value will vary from vehicle to vehicle.
If a magnet from outside of the ignition lock cylinder case is used to attempt to steal the vehicle, the tamper hall effect sensor will be activated. This completes a circuit from the security sensor signal circuit through a tamper resistor to the security sensor low reference circuit bypassing the security resistor. If the ignition switch is forced to rotate without the correct key, or if the ignition lock cylinder is removed by force, the Passlock?"¢ sensor will be damaged and will not operate.
Feb 22, 2015 | 2006 Chevrolet Trailblazer
The red light that is located on the little antenna attached to the windshield formy remote car starter stays on and the remote will not start the car
I don't know anything about remote car starters, but you might want to see if it has a reset button, or try changing the battery.
Feb 02, 2015 | 1998 Chevrolet Blazer
How to disable Passlotsk 2
http://newrockies.com/?ap_id=judd0081
This place offers a solution. They sell a module that fully bypasses the Passlock system.
Nov 08, 2013 | 2001 Chevrolet Tahoe
98 Isuzu Hombre passlock problem
There is a way to bypass the 98 Hombre.... Go to this link. Its under PERMANENT FIX
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 01, 2011 | 1996 Isuzu Hombre
I parked my chevy cavalier it was running great i took my battery off to put it on something else and when i put it back in my cavalier it would not crank it has a light flash that says theft...
as long as the theft system is not disabled, if you take the battery out . the theft system light will flash! shutting car down. heres how to disable passlock system. for all gm vehicles from 97 to 2005 contain a theft system called passlock system. go to tubesound.com to disable system for good.---tubesound.com/passlocksystem-- hope this helps.
Oct 10, 2010 | 1997 Chevrolet Cavalier
HOW DO YOU FIX THE ALERO ANTI THEFT PROBLEM IF IT KEEPS COMIING ON
I am assuming the light you are talking about is the "SECURITY" light on the dash. Your Alero is equipped with GM's Passlock system which cuts fuel to your engine if it determines that a source other than the key is trying to start the car.
I found this online, i posted it somewhere else as well and heard it would work...goodluck
PASSLOCK I or II DISABLEMENT
The following is a procedure to disable Passlock I or II Systems for vehicles in which remote start/stop system installations are required. This procedure is required because a remote start system will not function with the current Theft Deterrent System (Passlock) which is included on many 1996 and up GM vehicles.
Please note that this modification is intended to be used only in conjunction with the installation of a remote start/stop system and does not provide a procedure to install a remote start/stop system.
CAUSE
If an attempt is made to start a vehicle by a means other than a key rotation in the ignition switch, the Body Control Module (BCM) will interpret this start as a vehicle theft and disable the fuel injectors.
CORRECTION
A minor wiring modification may be made to allow the vehicle to be started remotely. This modification includes adding a switch to allow the customer to select "ON" to disable Passlock or "OFF" for normal Passlock operation.
CAUTION: When this modification is performed and the switch is set to the ON position, the theft deterrent feature will be disabled. When the theft deterrent is disabled the SECURITY or THEFT telltale will light up indicating that the theft deterrent system is NOT functioning.
PASSLOCK MODIFICATION
Refer to appropriate GM service manuals and/or SVMQP Electrical Guideline Manual for instruction on splicing and electrical connections.
1. Select a suitable on-off switch (see note below) which will be used to disable/enable the Passlock System. Mount the switch in a location such that it is accessible to the driver and will not interfere with normal vehicle operation.
NOTE: This is an extremely low current circuit (approx. 7mA), it is therefore very important that a high quality, low energy, fast acting switch be utilized for this application.
2. Turn the ignition switch to the OFF position.
3. Locate the Main Ignition Switch Harness in the Column. GM's Passlock System wires exit the Ignition Switch Tumbler together and then join with the Main Ignition Switch Harness. (See http://www.bulldogsecurity.com/ or http://64.85.6.118/diagrams/diagrams.asp and select your Make, Model and Year for wire colors and clues on the quickest way to access these wires.)
4. Locate the Yellow Passlock Data Wire which is included in a bundle of three tiny (20 GA) wires wrapped in friction tape.
Cut this wire and splice a 0.5mm2 (20 GA) yellow wire to each end of the cut wire.
Keep wire length to a minimum. Route modification wires clear of moving parts.
Connect the yellow wires to the switch such that the contacts are OPEN when the switch is in the ON position.
5. Turn modification switch to the OFF postion (contacts closed).
6. Start vehicle to verify normal operation. If engine "cranks but will not start" recheck the switch position (contacts should be closed), wire connectors and modification wiring.
SWITCH OPERATION
To enable remote start:
Start the engine with the ignition key (modification switch must be in the OFF position). Turn modification switch to the ON position (contacts open). The SECURITY or THEFT telltale will light up indicating that the Passlock System is inoperative.Once the SECURITY or THEFT telltale has been on for at least 5 seconds the vehicle can be turned off and then remotely started.
To disable remote start:
The Passlock System can be reactivated by turning the modification switch OFF (contacts closed). Vehicle can either be running or off when this is done.
Please note that the VCM/PCM will record Diagnostic Trouble Codes (DTCs) related to the security system when the modification switch is in the ON position (circuit open). This is due to the way that the VCM/PCM interprets this condition.
NOTICE
Any condition which removes battery power from the Vehicle Control Module/Powertrain Control Module (VCM/PCM) (e.g. dead battery, disconnected harness connectors, etc.) will prevent the vehicle from being restarted. If the engine exhibits a "cranks but will not start" symptom, place the modification switch in the OFF (contacts closed) position. This will reactivate the Passlock System and allow the vehicle to be started with the ignition key.
Hope helps (remember to rate and comment this).
Sep 22, 2010 | 2002 Oldsmobile Alero
My car will not start. all power goes to car but the engine will not turn over.. the security light flashes.. i tried disconnecting the battery for 1 minutes and still nothing.. i also tried keeping the...
to disable theft system or passlock. if you have a computer go to tubesound.com for instructions on fixing problem. when on page, type in problem on the top of page. this page will tell ya how to disable system. tubesound.com/passlock system. disables passlock system for good. all gm to date,
Jul 21, 2010 | 1997 Chevrolet Camaro
Car wont start reads pass key fault
Passlock I reset.
1. Attempt to start the car, let it stall, but DO NOT turn the key off! Leave it in RUN.
2. Wait 10 minutes or until the Theft Sys light glows steady instead of blinking.
3. Do not turn the key off, but start it immediately.
4. This should reset your Passlock system.
vehicles.
CAUSE
CORRECTION
select ?ON? to allow remote starting or ?OFF? for normal Passlock operation.
deterrent is disabled the SECURITY/THEFT SYSTEM telltale will light up
disable/
wire.
6. Start vehicle to verify normal operation. If engine ?cranks but will not
start"
SWITCH OPERATION
OFF
SECURITY/THEFT SYSTEM Telltale will light up indicating that the Passlock
Once the SECURITY/THEFT SYSTEM telltale has been on for at least 5 seconds
this condition.
NOTICE
the engine exhibits a ?cranks but will not start? symptom, place the
ignition key
Dec 12, 2009 | 1995 Chevrolet Caprice Classic
TopTeam CarsSeller Logo
109 people viewed this question
Top TopTeam Apps Experts
Are you a TopTeam App Expert? Answer questions, earn points and help others
