Question about Garden
Mcculloch trimmac 210
I just replaced the fuel line on my petrol trimmer but I cant seem to prime the petrol up to the bulb and carb. the bulb does not appear to be split or leaking. I was wondering if it could be the fuel pick up in the tank.
  • 376 Answers
SOURCE: Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
Posted on May 24, 2009
  • 199 Answers
SOURCE: primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Posted on Jun 10, 2009
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
suzukiracing
  • 200 Answers
SOURCE: Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
  • 640 Answers
SOURCE: Replaced the primer bulb and
Chances are the primer bulb is hooked up backwards, I did that once, made me feel pretty foolish.
Posted on Jul 29, 2011
PowerMac by McCulloch PM425AV-18 38cc. I have replaced the line from the fuel mixture tank to the primer bulb & replaced the primer bulb. Now the chainsaw won't keep or looses the prime. Now...
Are you sure you have conected the pipes the correct way round, the fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, nearest to the alloy pump cover, the other conection off the carb goes to the shorter conection on the back of the primer, the longer pipe on the primer goes back to the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Ratio of oil to petrol for a McCulloch Trimmac 240
normal mix for pet/oil is 50:1 but it depends on the oil you use
Jul 11, 2010 | McCulloch Trimmer Plus Attachment: Add On...
Asked to repair a McCulloch wipper snipper model TM251SST+. Found fuel line inside tank perished as well as outside primer bulb. Replaced with new. The petrol does not pump up when primer bulb pressed. I...
the primer bulb has the valves in it ,check the in line fuel filter.take outlet off primerbulb,should pump thru from tank,thru the primerbulb
Jul 11, 2010 | Garden
I need a manual for my mcculloch trimmac 210 does any one know where i can get one?
you can go to:
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
and click where it says
Download the complete user guide
before you can download the manual (11 pages), you'll be asked to rate the trimmac 210.
Hope it helps
Marcos
Jun 16, 2010 | Garden
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to adjust the fuel flow in a Walbro carburetor
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Make surethe small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Dec 01, 2009 | McCulloch Garden
How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Aug 31, 2009 | Black & Decker 14" Grass Hog Xp...
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
