Question about Philips 42PF9966 42 in. HD-Ready Plasma Television
Factory reset phillips - Philips 42PF9966 42 in. HD-Ready Plasma Television
How to factory reset a phillips 42PF9946/79 tv without a remote?
Do a factory reset on it and it will work again.
Dec 17, 2017 | Televison & Video
Phillips 32 PF5320/28 will not auto detect antenna stations. TV set on antenna, go through auto detect, nothing. Just another typical Phillips product?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Sep 10, 2017 | Televison & Video
I have a Phillips 46" Tv Model 46PFL3608/F7. When I turn it on it will show the Phillips logo for a second then turns off.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Oct 04, 2016 | Televison & Video
Phillips flat screen tv left half of screen is black right side is dim and flickering
Is your tv less than a year old? You need to call Phillips and see if it is covered under warranty. If that is not the case you need to get a few estimates. You want to know if it will be cheaper to repair or replace your tv set.
1 888-744-5477 Phillips customer service number
Aug 14, 2016 | Televison & Video
My Phillips flat screen TV keeps going to menu while playing
Main system control memory IC fault. Replace it. Before replacing, try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 02, 2015 | Televison & Video
Is there a fast easy way to reset my phillips 42 lcd tv.it comes on and then shuts down.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 25, 2015 | Televison & Video
I Have a Phillip 22 inches lcd TV. I think it is a hotel used TV. I tried changing the language to English in other for me to tune the channels to Nigeria station but mistakenky lock the memory. Nothing is...
Just do a reset [factory reset] to this TV, and check. If it do not help you, contact the authorized service centre for Philips. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 06, 2014 | Televison & Video
I have a Phillips sound bar with subwoofer. Model # htl2151/f7. The light is illuminated for power but will not change source and has no sound at all. Please help
Do a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 03, 2014 | Televison & Video
Where is the reset button on my phillips tv model 27pt6441/37
There is no reset button on your TV. However, if you unplug it for at least 10 seconds, it will clear any power faults that it may have detected.
If you need to access the menus and have forgotten your access code, the factory code will work.
0, 7, 1, 1 code is the factory default and can be used to enter and create a new access code.
Dec 03, 2010 | Philips Televison & Video
Trying to reset a PCto factory defaults
There is a neat site:
http://www.user-guides.co.uk/asp/search.asp?keywords=User+Guides+Phillips+MT2400&recor=1
They have everything you need. Look at the Bios jumper ad reset it.
Hope this helps.
Jan 27, 2009 | Computers & Internet
Philips 42PF9966 42 in. HD-Ready Plasma Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
