Question about Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave
No power for fgmv174kfc
Unit is not powering on. No lights, display, etc.
Micro wave went dark on display screen, but outlet has power; where is the fuse
The fuse is located inside. The outside cover has to be removed to gain access.
Sep 16, 2014 | Frigidaire Microwave Ovens
Door window replacement. can I replace the glass in the door of my microwave.
Good Afternoon Friend,
I understand that you want to replace the glass in the door of your Frigidaire microwave, model# FGMV174KFC. Yes, you can replace any glass in your microwave that you choose. However, for safety reasons, I do suggest contacting your local authorized technician for the replacement of the glass. They are trained on your particular, model and will be able to ensure that the door is put back together and installed correctly, alleviating any safety issues. Hope this is helpful.
-Best Regards-
WP
May 23, 2014 | Frigidaire Microwave Ovens
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
Panasonic NN-CD997S microwave
i have microwave problems power trip when switch on the unit. please help me.
Jan 06, 2010 | Panasonic Microwave Ovens
Panasonic Microwave NN-T993SF has no power. Was working and suddenly the power went out like it was unplugged. It is not our fuses or cord but something in the microwave itself. Is there a fuse or...
most microwaves do have an internal ceramic fuse either 15 amp or 20 amp the cover has to come off to locate it usually at the top just behind the control board. do not touch the high voltage capacitor as it holds a charge even when the unit is unplugged.
Nov 07, 2009 | Panasonic NN-T993SF Microwave Oven
No display will not operate no fan no light
Ok, there is an in-line fuse that is located inside the unit on the power supply board. if this fuse is damaged, replace it. If this fuse is ok, replace the entire power supply board.
Jun 01, 2009 | Whirlpool GH4155XP Microwave Oven
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Power but no display to unit
Not sure about the Neff brand, but in general you'd want to check for 110VAC power on the primary side of the low voltage transformer on the control panel / board. If that is present, check the secondary for voltage, about 12-30VAC. If the unit has a VFD type display, there will be a heater filament supply, usually around 2.5-6VAC. Also look for bad connecitons on the VFD. If those voltages are present, check connections on the board, look for bloated / bulging capacitors, shorted diodes, breaks in the board, etc. Also look for thermal cutouts and thermostats. If this doesn't fix it, can you take several photos of the inner parts and circuit boards?
Sep 26, 2006 | Neff H7871A2GB 800 Watts Convection /...
Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave Logo
329 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
