Question about Canon Pixma iP4500 InkJet Printer
Canon pixma ip4500 green and orange lights flashing
  • 3 Answers
SOURCE: Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Posted on Feb 17, 2009
SOURCE: canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Posted on Apr 24, 2009
huntwolfe
  • 20 Answers
SOURCE: "Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Posted on Oct 02, 2009
SOURCE: error b200, green and orange lamp flash
orange light blinking
Posted on Dec 29, 2009
  • 1833 Answers
SOURCE: orange light flashes 5 times continuously on canon
Orange light flashes if there is any issue with the printer. Please check all the hardware is functioning properly. Check if there is any paper jam. If printer cartridge is installed properly. Printing head is ok.
Posted on Dec 09, 2010
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error) What can I do?
Refer to Canon documentation
Five flashes: Print Head is not installed./ Print Head is defective
please check correct placement with your cartridge, maybe it's not installed properly
May 09, 2011 | Canon Pixma iP4500 InkJet Printer
I put in a new ink and my canon ip4500 came up with service error 5c20 and the orange light started flashing how can i fix it?
It has not detected the cartridges correctly or it has a waste ink problem, not sure which. Are they genuine Canon carts? I hope this helps will you let me know how you get on please?
reseat all the cartridw0zz_3.jpgges and read the attached which should work with the 4300 (thanks also to tech1569 for this)
Jan 26, 2011 | Canon Pixma iP4500 InkJet Printer
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
Hi, i geting problem in inkjet printer connon
These are the instructions which worked for me on my Canon pixma ip470 bought August 08:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.
Jan 08, 2010 | Canon Pixma iP4500 InkJet Printer
How to reset waste pad for Canon IP4500
First, replace the waste pad with a new one....
1. With the printer turned off, press and hold down the resume/cancel button, then press and hold the power button. Do not release the buttons. the power led should come on green...
2. Release the resume cancel button, bur keep holding down the power button....
3. Press the resume/cancel button twice (Still holding down the power button) The Alarm and Power LEDs should alternate with each press...
4. Now release both buttons.
5. When the Power led is green, press the resume/cancel button 4 times only. The Alarm and power Leds will alternate, green, orange,green orange, green...
6. Now press the power button. The paper lifting plate should raise.
7.Reboot the device. That should do it...
Good luck
Dec 20, 2009 | Canon Pixma iP4500 InkJet Printer
I wanted to reset counter printer for pixma ip4500. what's your sulition for this problem without go to canon agancy? tanx
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 10, 2009 | Canon Pixma iP4500 InkJet Printer
Canon PIXMA iP1000 Printer - don't work
GO ON LINE
CANON PIXMA iP1000 7 FLASHING LIGHTS
ENTER
ROD
Feb 04, 2009 | Canon Office Equipment & Supplies
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma iP4500 InkJet Printer Logo
37 people viewed this question
old marine
old marine
