Question about Datacard Group Office Equipment & Supplies
L1 supply error - Datacard Group Office Equipment & Supplies
What does error code L1 mean on my chigo air conditioner unit
When posting hardware questions, it is useful to post brand and model number. There are a number of Chigo air conditioners. I have examined an error code page for the brand and the error L1 is not listed. However, on page 25 of the following manual, L1 is identified as a current transformator of which there can be a No-voltage for over-c
urrent detection circuit. See 4) Electric control panel detection sub-number 3 on that page.
http://www.investliving.se/upload/images/Produkter/Luft-Luft/New%20Basic/Service%20Manual%20New%20Basic.pdf
Dec 18, 2017 | Heating & Cooling
What does the error code L1 mean
Make and model or at least SOME idea of what the piece of office equipment is would be useful.
See the link
error code L1 Google Search
Dec 18, 2017 | The Office Equipment & Supplies
System error L1-00 on Toshiba e studio162D copier how can I reset this copier?
Have you tried googling this yet, asking your IT person, or reading your manual? lol
Mar 20, 2017 | Toshiba E-Studio 162 D
What is no_PO error
no_PU = No power unit. 24Vdc is being supplied to the control card with no AC voltage (230 or 400) being supplied to L1/L2/L3.
Verify AC voltage is present at L1/L2/L3.
*If not present, apply voltage and no_PU should clear. *If present and unit still no_PU, there is a problem with the power stage. At that point unit should be replaced or repaired.
May 06, 2016 | Inverter KEB COMBIVERT F5
What is error code f69 on a frigidaire electric range
Hello. You have a serious problem--that error code means L1 or L2(the 120v supply wires) may be shorted with the neutral on the incoming power supply. TURN OFF THE POWER!! Check the wiring at the terminal block. The neutral is the center post. L1 is usually black and L2 is usually red. The F68 and/or F69 error means high voltage or the above-mentioned condition. Once you have verified there is no incorrect polarity or voltage condition, then the main oven control board must be replaced. The part number you might need is 316562011. I hope I helped you!
Sep 20, 2015 | Frigidaire Kitchen Ranges
My calculator won't let me graph or find the linear regression.
You have attempted to use, edit, or delete an archived variable. For example, the expression dim(L1) produces an error if L1 is archived
Nov 03, 2017 | Texas Instruments TI-83 Plus Calculator
Error code 000804
Hi Error code 000804 is normally a cooling fan ..check the power supply cooling fan is prob a filter has got dislodged during transport and is stopping the fins from turning
Nov 08, 2011 | Canon iR5000-6000-L1 PS Ver 1.0
What mean L1 and L2 for the connexion of the heater
L1 Means Line Voltage L2 means Line Voltage
If you have 220 as your supply voltage than one side would go to L1 and the other to L2.
Hope this helps if you still have problems post another post along with more information as to what voltage you have.
Jan 02, 2011 | Dimplex EF621C Electric Wall Mounted Panel...
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
89 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
