How to restart a certikin genie pool boiler with error 4
2 Suggested Answers
  • 3 Answers
SOURCE: I have a Certikin Genie
You could try resetting this as it could be caused by several factors (blown heat exchanger being one as Karl mentioned).
Hve you tried resetting from in Service Mode ?
To get to Servce mode you need to go ino User Setup Mode first (turn off the boiler via the panel switch - then hold the Lock/Reset button whilst turning back on). Once in User Setup Mode if you rotate the thermostats all the way clockwise (it should display the software version) Then press and hold the Lock/Reset button for 3 seconds.
This should put you into service mode and it is now possible to change/reset some of the control parameters.
If you try resetting the error.
This issue may be caused if the Flue or water stat is tripped (in which case reset the stat). If th Fan resistor remains open in the circuit then you will need tsomeone out to investigate as that may cause the GAS error too.
COuldalso be the Valve coils are faulty in wich case they need replacing (agians I would get an engineer outto confirm and do that).
I'm suyou probably tried all this but just in case...
If the roblem is solved can you advise what fixed it ?
Thanks
Posted on Jul 01, 2013
Certikin 11kw pool heater only luke warm, how long does it take to heat a 10ft pool? And will it let out hot water?
water flow too fast bypass with plumbing and only let half or a third go through heater if jumps around and shuts off let more through
May 19, 2015 | Pool & Spa
Tip
Solving Salt Water Pool Problems with The Chlorine Genie Chlorinator
Salt Water Pool Systems often are a consumer disappointment when users find out the problems, costs, and maintenance problems of this popular pool technology. Today's video covers some of the common drawbacks, dangers, and problems and offers resources for a solution.
on Nov 08, 2016 | Zodiac Lm3-40 Salt Water Chlorinator...
Tip
The big problems with salt water pools is actually the salt in the pool water itself. Salt water chlorination has many benefits over standard pool chlorination methods, but with a salt in the pool system there are significant drawbacks, hidden expenses, problems, and potential dangers. The best way to enjoy salt chlorination is to get the salt out of the pool. The Chlorine Genie Pool Water Management System does just that. In fact the system can produce and take care of up to 5 important pool chemicals for you. If you are fed up with salt water pool problems and ready for the cutting edge in pool water sanitation, check out the new advantages of Chlorine Genie's Chlorine Generator Technology.
Chlorine Genie Inc Martinez 94553 The Ultimate Pool Chlorinator
Check out the Pool System Videos on YouTube at: Chlorine Genie
Get Social and Join the Pool Party at: https://about.me/chlorinegenie Chlorine Genie on about me
on Nov 08, 2016 | Pool & Spa
Causes of flame failures on raypak boilers
check to see if you have proper gas pressure it sounds like it is overheating
Feb 09, 2014 | Raypak Pool & Spa
Boiler won't reset error message is air pressure sw
Check the induced draft pressure switch's tubing that connects it to the induced drat assembly, the barbed port that the tubing connects to gets clogged requiring reaming annually or this will happen, if this does not work replace the switch, make sure to clear the port.
Dec 07, 2013 | Lochinvar ENERGYRITE 400K BTU PROPANE GAS...
Boiler will not reset
Dec 07, 2013 | Lochinvar Energyrite Residential Heaters...
Boiler manual
if you all ready replaced is not suppose to leak more water this pressure release valve are reated to 75 psi pressure some of them
Jun 09, 2013 | Teledyne Laars Pool & Spa
Boiler ignition is loud, boiler runs for a few seconds then goes out
flame sensor, air flow restriction or blower not producing enough pressure. clean the flame sensor to start. inspect venting, etc
May 13, 2013 | Jandy Lx Pool & Spa Heater - Electronic...
My 4 years old LAARS boiler Makes whining noise when it's runing.
The tubes in the heat exchanger are most likely clogged with gunk, you can flush the boiler with tri-sodium phosphate. you must isolate the boiler from the system in order to acomplish this
Jul 06, 2009 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
I have a Certikin Genie swimming pool boiler that is showing the word GAS and i can smell it. What should i do?
Thanks
Jul 13, 2008 | Heating & Cooling
Heating & Cooling Logo
289 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
